Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
Cuisinart CBT-500 blender won't work
Use this infrequently & have had no problems. Went to use it last night and it won't work. The red indicator lights come on and when you it a button the timer starts to count ("1), but no motor noise or spinning.
Thought the cap was not on tight enough (to make the connection with the base), blade mechanism will spin if I manually move it (so it's not stuck). It'll be 4 years old this month.
  • 2 more comments
  • Adrift Apr 28, 2008
    Lights on but nobody's home: buttons and timer come on, but no motor movement at all. Is there an internal fuse or reset on this thing? I've taken the base off and the wires seem connected.
  • MOM2EMY Jun 01, 2008
    i USED THE BLENDER LAST NIGHT TO MAKE SMOOTHIES AND TODAY IT WON'T WORK AT ALL. iT LIGHTS UP BUT WON'T RUN.
  • Anonymous Dec 17, 2008
    blinking light starts and the timer gos to 5 mins. but the blender does not go on at all
  • Anonymous Jan 10, 2009
    Exactly the same issue here as well. worked fine last night.
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Posted on Nov 22, 2009
    Problem Solver:
  • 16 Answers
Plz cont - 23051554 \ 23095757
Posted on Aug 05, 2008
2 Suggested Answers
SOURCE: replace the blade driver clutch on a Cuisinart CBT-500
I had this same problem. It was solved but let me tell you it was a nightmare and we were almost sure the blender would be destroyed at least 3 times during the ordeal.
Here's a hint: the thread is on opposite to a normal screw thread so that it gets tighter as the blender spins.
Steps:
1. Take the base off the blender and pop out the motor.
2. Turn over the motor and remove the round rubber part at the bottom. You will see a flathead screw. This is where you grip the shaft that the cursed brass coupler thread is attached to.
3. Find someone else to help and also a large strong flathead screwdriver.
4. With a friend holding a screwdriver in place at the bottom, grip the top brass thread with pliers (or better yet a pipe wrench) and twist it the opposite way you normally would.
5. Become extremely frustrated by the fact that the screw thread is made of cheap metal and strips instantly and that the brass thread is also cheaply made and rips right through your pliers / wrench.
6. Find a hack saw and a hammer.
7. Cut the brass thread off with the hack saw. Hammer the stubborn remaining pieces of it off with a screwdriver. Be prepared to cut off half of the shaft.
8. Eventually you should have hammered / sawed the brass thread off. If the shaft and motor are still intact, you can now screw the new coupler on (remember - its backwards). We had only about half of the shaft thread left and it still worked ok. Make sure to do this after you put the motor back in place with the shaft poking through the top of the case. Don't worry too much about how tight it is. As I mentioned its on backwards to tighten the coupler during normal use.
9. Replace the casing and screws, don't forget that rubber thing at the bottom.
10. Curse Cuisinart and make a drink, you deserve it.
Posted on May 13, 2008
Need a motor for a cbt 500bw cuisinart
Cuisinart websites for both Canada and the US have parts ordering services; however they do not list parts like blender motors.
I woud suggest you contact their Customer Service to inquire if and how a motor may be made available.
Customer Service contact information is available here:
http://www.cuisinart.com/support.html
Jun 13, 2012 | Cuisinart CBT-500 SmartPower Premier Work...
Power light blinks and blender won't turn on
Probably just a fuse. Also try a different outlet. Check the manual for fuse location and other possible solutions.
Download Cuisinart CBT 500 Manual at Bob Manuals
Apr 11, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
My blenders just stopped working. do you have any sugestions
Consult the manual for troubleshooting tips. Other than that you may want to get a new blender as repairing it would be more costly than the unit itself.
Jan 16, 2010 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart bc56 blender
how to get the base off the glass container. turn in what directionss it seems stuck
Feb 27, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Thermal cut off fuse replacement
I worked for sunbeam and they were 10amps there. dont go to high because u start a fire ..also while you replace it look for darker or blacking field wires..all wires should look good. but hard to start a fire when u got your finger close to off the button at most it will do is slow down and stop ...smoke...time for new blender then. CrazyLarry
Jun 03, 2007 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
3,565 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
