Question about Cameras
Vivitar 3200 Flashgun and Canon EOS 400D
Please advise me if Vivitar 3200 Flashgun and Canon EOS 400D camera are comparable. Can I use the Vivitar 3200 flashgun with the 400D without any damage to the camera?
  • curiographic Dec 09, 2008
    Is it possibe to use Vivitar 3200A flashgun with Nikon D80 if so where do it get its instruction mannual
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Posted on Jan 02, 2010
Yes u can. i use it with manual mode and it works fine
Posted on Nov 09, 2008
Is it compitable with sony alfa 200
Posted on Sep 30, 2008
The internal flash on my canon eos 60d camera won't pop up
On the hot shoe when you fit a flashgun it pushes two tabs down to disengage the pop-up flash some times the tabs don't fully return after flashgun removal
Jan 17, 2016 | Canon EOS 60D Digital Camera
EOS 60D. Why doesn't flash raise?
On the notable under the rails there are two thin contacts that are pushed down when a flashgun is fitted and spring back up when it is removed some times it doesn't return
Get a micro screwdriver and gently move the contacts till they connect the underside of the rails
Jan 01, 2016 | Canon Cameras
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
Hey guys. I use my old vivitar 728AFC flashgun on my canon 550d (T2i). the flash works but does not communicate fully with the camera, however my problem is; when set my camera ss higher than 1/200 it...
Hi, the flash in question will not work in TTL mode even though it has contacts on the bottom that may indicate that it could...... so it will work in auto or manual mode but not adjust itself. All adjustments will have to be made manually.
Sep 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
What flash will fit the V3800N SLR film camera?
Pretty much any flashgun with a standard hotshoe. The 3800N is extremely basic and does not take advantage of any dedicated flash functions, so you'll find loads of cheap or even free basic manual or auto-exposure flashguns on auction websites and also on FreeCycle.
I'd suggest a basic manual flashgun as you then fully control it. Automatic flashguns try to second guess what it is you're photographing so can often over-expose the subject. You also learn more using a basic manual flash which is probably the only reason to buy a 3800N in the first place.
Jul 29, 2009 | Vivitar V3800N 35mm SLR Camera
My Canon EOS Rebel 35mm SLR camera seems to be giving random pictures which are black half way down from the top. What can cause this?
One of the shutter blades is faulty or is being obstructed. Either that or you're using flash to take pictures but using too fast a shutter speed, most SLR's have a flash synch speed of 1/60 or 1/125 of a second.
The first problem will need a professional repair, but it may be a fairly straightforward one. The second problem would require that you read the user manual for both the camera and flashgun.
Jul 01, 2009 | Canon EOS Rebel G 35mm SLR Camera
I need a manual
Google this: canon 400d manual You should find a PDF file you can download. But really, that flash is pretty simple to use. Just stick the camera on automatic and it does its thing.
Jun 09, 2009 | Sunpak PF30X for Canon Flash
Vivitar 636AF Flashgun
I do have the same unit that I am currently using on a EOS 10D. It works fine for me. It lso operates on my EOS 350D but does not flash off quite bright enough on this camera in very low light.The unit was previously paired with a canon EOS 5 film. You can contact me at a.blast@rocketmail.com for required information.
Aug 31, 2008 | Cameras
Flash Gun Broken can it be fixed
Buy distilled water.
Try to open the flash apart.
Pour distilled water to unit and blow dry or just set it near sunlight until dry.
atdlee@netzero.com
Jul 30, 2008 | Vivitar 283 Flash
Cameras Logo
2,296 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
