Hi masters: My computer go realy slow,when you stop using it for 10 min.I have installed a CA security anti virus,etc ,but still reporting one virus that the CA anti,hasent been able to clean so far.Sometimes it frees to the point that i need to reset to be able work again.What can i do,thanks
  • Iqbal Husain
    Iqbal Husain May 11, 2010
    hmmm if you have any other anti virus, then you shuold uninstall the previous antivirus and installed the next one. then make a complete system scan. Then it will be fixed.
    President:
  • 2,351 Answers
You need to find the path to where the virus file is located & delete it you're self. You're antivirus software should show you where it is located. Once you delete the virus file, shut down the PC. Unplug the power cord from the PC. Open you're case & remove you're memory. Wait about 15 seconds & reseat you're memory. (make sure you're memory is seated correctly).
Removing the memory clears the memory from memory virus).
Close you're case & reconnect the power cord. Boot the PC. Once windows has finished loading run windows diskClean, than run windows defrag. (may take some time). After defrag has finished restart you're PC. Run another virus scan. If you're virus software still finds a virus or you're system & its still running slow the virus may have damaged windows files or windows registry. A reinstall of windows may be needed. If you have system restore turned on than the virus is most likely being stored in one or more restore points.
Remove infected files that you cannot clean in the System Restore data archive. To completely and immediately remove any infected file or files in the data store, turn off and then turn on System Restore. To do so, follow these steps:
1. Click Start, and then click Control Panel.
2. Click Performance and Maintenance, and then double-click System.
3. Click the System Restore tab, and then click to select the Turn off System Restore for all drives check box.
4. Click OK, and then click Yes to initiate the restore point deletion.
To turn on System Restore again after the restore point deletion has completed, repeat these steps, but click to clear the Turn off System Restore for all drives check box.
Good Luck!
Mike
loadTOCNode(2, 'summary');
Posted on Apr 13, 2008
My Dell Inspiron E1505 will be on for half an hour to an hour before Windows Explorer (and pretty much everything else) stops responding and I'm forced to turn it off. I've run registry cleaner,...
Hi vincent172...
I think you have a virus,worm,trojan,etc on your computer.
Go to the following website and download,install and run the FREE Microsoft Safety Scanner.
It will remove the virus,trojan,worm,etc from your computer.
It may take quite a while to finish, it all depends on the size of your hard drive.
Once the Microsoft Safety Scanner is completed running, it should have removed the virus,trojan,worm,etc. from you computer, but if it didn't remove the virus,trojan,worm,etc from your computer then it will give you an option to connect (real time) with a Microsoft professional (FREE) and he will take over control of your computer (with you permission) and finish the removal process.
Please take time to rate me thumbs up
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Sep 17, 2011 | Dell Computers & Internet
Tip
How to speed up computers.
**1The main reason which slowdowns system is VIRUS ATTACK.
Powerful tool to avoid this is installing Anti Virus.
Anyhow installing a anti virus is not sufficient.You need update the anti virus continuously(once for a week)
Updating means:-Hackers will generate the viruses and they will upload those viruses to internet data base every day.Which enters our computer when connected internet.The companies which provides the anti virus software will scans those viruses and they update those virus name our anti virus data base so that if any programs by those virus names which are in anti virus data base.Anti virus will block those programs.
So It's necessary to update the anti virus program continuously.
If you have genuine Windows operating system you can use "Microsoft Security Essentials" for FREE.
**2The reason which slowdowns PC is creation of unwanted sectors in hard disc.
For this Defragmentation is the best method to clear unwanted sectorsTo defragment the hard disc Select the partition>Right click>Properties>Tools>Defragment disk>Defragment>ok
Watch this...
**3)Another aspect which slow downs the system is creation of error sectors
you can use Check Now option to clear error sectorTo activate Check Now*Select the partition>Right click>Properties>Tools>check nowIt check for error during next reboot
**You can use "CHKDSK" command in DOS(instant check)
**3)You can use Disk Cleanup to delete temporary files,offline pages,log files, queued and error reports(These files are not important and files consumes much memory which can't cleared by us so we need to use Disk Cleanup.
To use this thisSelect the partition>Right click>Properties>select Disk
Cleanup (Disk Cleanup can be used for C: drive only effectively(Because temporary files,offline pages,log files, queued and error reports are saved in C: only)
**Options and Menu's are with respect to Windows7 & Windows related operating systems.
Thank you have a nice day
on Jan 30, 2011 | Computers & Internet
Computer is running real slow and cant find restore disc to redo computer
Hi dmwm1996
There is a few things you can do to speed your computer back up...
1...Clean up your hard disk...
Go to Start>All Programs>Accessories>System Tools>Disk Cleanup
2...Defrag your Hard Drive...
Go to Start>All Programs>Accessories>System Tools>Disk Defragmenter
3...Add the maxium amount of ram to your computer that is allowed
4...Clean any old programs, files,pictures,etc off of your computer that you no longer use.
5...Last but not least...
Your computer may be loaded with spyware, virus's, trojans,etc. and that will make your computer run slow also.
To get rid of any spyware,virus,trojan,etc you will need to do the following:
Download,install and run Microsoft Safety Scanner...
It will clean your machine of spyware,virus's,trojans,worms...and the best part...it's FREE
Go to the following webpage and download Microsoft Safey Scanner.
Sep 15, 2011 | Gateway 5200S PC Desktop
Computer runs SLOW after installing CA virus software, and now it has locked up and non-responsive for 20 minutes
other than uninstalling CA, it has a minimum memory requirement of 512k however it runs like a dog on this am mount , it is recommended that you have at least 2gb of RAM to run CA antivirus.
Mar 20, 2011 | Computer Associates CA Anti-Virus
My phone dont show miss calls , dailed calls and receive call
HI durqaqrq99....
You Problem is related to virus attack.
Try the following.
*Restore your phone once(To Restore Go to Menu>Settings>Restore Factory Settings>Ok(Default Security code is 12345)>Yes(It takes 1-2mins).
*Scan your phone and memory card from a updated anti virus.
At Last.... if Problem persists.....
You need to flash(format)your phone.
Formatting resets the security code to 12345
(formatting delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using PC suit)
To back up your files
*Install the PC suit
*open PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*PC suite of your handset
*Internet connection(Min speed 1Mbps)
*software updater(you can download by using PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(download the Software updater by selecting this option)
*Install the "Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Feb 02, 2011 | Cell Phones
Too much virus inside this mobile. There is not any virus cleaner inside this mobile .always stop during runing after 5 min.want 2 get online cleaning free if available.
use f-secure. but the thing bout f-secure is, it only gives you a month for free updates. You could extend it by paying for new subscriptions though but for me, anti-virus aren't really necessary on our N73 as it cannot in any way target the OS and destroy it directly. You must take note that applications for N73 undergo signing process, thus making it much more secure than of the previous versions. If ever there would be a virus that could enter your phone, one great harm that it can do to your phone is to slow it down but it is a fact that it couldn't trigger your OS. Even I myself don't use anti-virus applications, it takes too much of your ram and free space, it slows down your phone a lil bit too. Just be vigilant mate... No virus could be tough enough to pass through a human-firewalled N73.
install the Netqin antivirus.download it from here
Jan 27, 2011 | Nokia N73 Cellular Phone
Do I need a Norton-type security for my laptop, or is AVG sufficient ?
AVG is more than sufficient for a home computer.
Norton takes quite a lot of system resources and slows computers down dramatically. AVG on the other hand uses 2/3rds less resources than Norton and is just as good.
Reagrds.
Sep 14, 2009 | Acer Aspire 3000 Notebook
My browser Internetexplorer is working too slow or not working
try uninstalling kapersky and then try internet explorer
Mar 14, 2009 | Microsoft Windows XP Home Edition
Anti Virus
Kapersky Internet security is the complete software suite, and it does include, firewall, internet security and some anti spyware feature.
Internet security is better, but it will also slow down the computer more.
If you have a good computer with at least 1 GB RAM, and CPU at least 1.6 GHZ intall Internet security. If the computer is slow or it is an old computer, then install antivirus only, and be more careful.
Oct 04, 2008 | Computers & Internet
Remove file
Here is more info on the critter:
http://spywarefiles.prevx.com/spywarefiles.asp?FXC=BHJI036815472
1) Reboot windows in SAFE mode by pressing F8 during the
boot repeatedly.
2) Use a virus remover like AVG or Kaspersky
3) Alternately remove the files manually.
4) If the files refuse to be removed, reporting a locked file
error, download a product called file unlocker:
a) unlocker1.8.5.exe or
b) who locked me from: http://www.dr-hoiby.com or
c) killbox.exe from: vbtechcd@gmail.com
d) File Assasin from:
http://www.malwarebytes.org/fileassassin.php
5) Any of these utilities will delete the file by brute foerce
if necessary
6) Download Mike Lin's Startup monitor (all 3)
a) Control panel applet
b) Stand alone program
c) Resident startup monitor
These three utilities will allow you to audit startup keys
in your registry and automatically stop rogue programs
from installing themselves without your permission.
7) Remove all suspicious programs from registry startup
locations:
HKLM = HKey Local Machine
HKCU = HKey Current User ....
Software\Microsoft\Windows\Current_Version ...
Run, RunOnce, RunOnceEx, Run SErvice, etc...
8) Install a reputable antivirus (with a license) and keep it
up to date:
e.g. AVG, Kaspersky, McAfee etc.
9) Disable most of the resident monitor function, because
these tend to slow your system down, BUT ....
Manually scan all downloaded files BEFORE
opening them
10) Download and install two free anti-spyware utilities:
AdAware by LafaSoft
SpyBot Search and Destroy
make sure you get these from the official sites,
beware of evil lookalikes.
11) Go to winternals WEB site, formerly Sysinternals,
and download security utilities by Mark Russinovich
(now at Microsoft)
Anti-rootkit and scanners for ADS
(Alternate Data Streams)
12) Go to F-Secure web-site, and download another anti-
root-kit utility called black light.
13) Download and install the Mozilla Firefox WEB browser,
never use Internet explorer (any version) except for
Microsoft updates
14) Install the following Firefox security plug-ins:
AddBlock Plus
ColorFul Tabs
Finkan Secure Browsing
Flash Block
Google Icon
NoScript (Very important, stops evil scripts)
Stop Autoplay
15) If you do all of the above, you will get very few viruses.
Martin
Jun 08, 2008 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
