Won't open from outside? Won't open from inside? Equipped with power door locks? IF so, and won't open inside/outside, suspect stuck power door lock actuator. Sometimes working the lock/unlock button will make the door unlock. If not, the door will require disassembly from inside to determine what the failure may be. If the door needs disassembly while in the closed position, the paneling/clips may get damaged FYI
My friend just had this problem and he reached in and pulled the inside door handle back as far as it would go, and then let it go, allowing it to 'snap' back. For some reason this fixed it. We have no idea why. By doing this on one door, both rear door locks freed up and the rear locks are now working. Before, both rear locks were stuck and you could not open the doors from the inside nor the outside. Not sure why it works, but maybe it will work for you!
sounds like a hinge problem or the locking device to the door. Might have to play starkey and hutch for a while and jump in the window. Just kidding !! I would take to the dealer and have them look at it. But it appears to be the locking device the way it sounds.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
You will have to roll window down and take very long screw driver to insert through glass opening and beak up latch assembly then door will open ,Then remove door panel and will be able to replace latch,Best done by proffessioal,one mistake can cost.
