Question about StarTech.com (ATXPOWER250) 250-Watt Power Supply
Atxpower250 I want to use this power supply to power an alarm annunciator (not a PC) I need a wiring diagram, to modify , (eliminate all but a 12vdc 100watt constant output)
    Problem Solver:
  • 5 Answers
The Yellow wires are 12v and Blacks are grounds..
Posted on Apr 30, 2008
I have a Clarion car audio system. I want to use it as an outdoor system on 120v. What kind of power supply does I need? Does something else should I take care of?
Car stereos require power for both red and yellow wires. You can twist them together, then black for ground. Not sure about your power supply setup. A standard ac to dc should work. Run speakers externally. Usually white and grey wires are front left and right and purple and green are the rear. good luck
Jun 15, 2016 | Clarion DB185MP Car CD/ MP3 Player
Wiring schamatic for annunciator
have u got a schimatic diagram?
Jun 01, 2012 | Hammering
Im putting power locks on my truck wanted to know where to connect the wires from the actuators to the alarm
Does the alarm support keyless entry if not you will need another alarm. If it does support look for any unused wires on the alarm module. Hook up a multimeter and look for 12vdc when pushing the unlock button on your remote
Jun 07, 2011 | Car Audio & Video
Charging laptop in car
Most inverters create a modified sine wave output, which is similar to, but not the same as the AC you get out of the wall. The power supply for many laptops (and most transformers in general) will not run with a modified sine wave input. There are devices available that skip the inverter and the power supply. They go directly from 12VDC to what your laptop needs.
Apr 23, 2010 | Black & Decker 200 Watt Power Inverter...
Will not boot to operating system or the bios. no messages and no beeps
You probably have a bad power supply or one of your components is bad. I don't have enough info to point to anything specific, but here is some ideas you can try.
1) unplug all components internally but the power supply and check for bios beeps. Not the front panel wires though.
2) swap power supply or check with voltmeter for +5vdc, +12vdc, and -12vdc.
3) check for operation of fans attached to motherboard.
4) most likely suspects are motherboard, processor, or power supply.
Nov 16, 2009 | Acer Aspireā„¢ T180 PC Desktop
Want to use the atx-300-12z as a hobby power supply. Need 12vdc.
You're asking for a fire or just burning out the power supply. But,at your own peril, check the yellow wires for 12v or buy a power supply test adapter from ebay. It bypasses the power switch usually done by the motherboard & will fire up the power supply like it was connected to a board. Then test the wires for 12v. Should be any yellow wire,red is 5v. Green is 3.3 or 3v.
Jul 22, 2009 | HP Bestec ATX-1956D 200w HP Part No...
W2888 emachine just shut down as if it were unpluged
THE LITTLE LIGHT ON THE MOTHERBOARD SHOULD ALWAY BE ON. THE FAN ON THE POWER SUPPLY RUNNING NORMAL OR FAST.
DID YOU ADD ANY NEW DEVICES TO YOUR COMPUTER LIKE UPGRADING THE RAM, VIDEO CARD, NEW INPUT DEVICE.
NEED MORE INFORMATION.
ROD
May 12, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
I need the wire diagram
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 08, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
Jan 20, 2009 | StarTech.com (ATXPOWER250) 250-Watt Power...
Power supply burned up
yes because the spare parts are not compitible and as it is burned if you opened it, warranty will void please give it as the condition
Oct 27, 2008 | StarTech.com (ATXPOWER250) 250-Watt Power...
StarTech.com (ATXPOWER250) 250-Watt Power Supply Logo
212 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
