Question about Teac SL-A100 Turntable
TEAC SL-A100 - runs only on 45 rpm I followed Jim's advice to another post and removed the back cover. The turntable assembly is not very accessible. Looks like the motor is plastic-welded in place. You can feel a belt. It runs only at 45 rpm regardless which speed the switch (33-45-78) is set on. Nice little turntable, only 4 years old.
  • bigjon1452 Feb 13, 2009
    Thanks for the follow-up. I sold it in a garage sale for $15 with a "needs repair" sign on it. The guy who bought it only wanted to play 45s so it was perfect for him.
  • Steve W May 11, 2010
    the belt is best accessed from the top by removing the platter disc or at least the mat to observe what is going on.
    does the speed switch feel right? solid?
    do you see a 'fork' around the belt near the motor on the left side? if so this would move the belt up n down the motor shaft.
CompuGuy44
  • 432 Answers
SOURCE: only spinning at 1 speed
This is a high dollar turntable. If you want, take the screws out, open it up and check that the direct drive speed gear is in place. Other than that I would take it to a repair shop. There's one guy on ebay selling a new one for $500.00 http://cgi.ebay.com/Technics-SL-1200MK2-Manual-Direct-Drive-Turntable-New_W0QQitemZ320132536688QQihZ011QQcategoryZ64448QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Jul 01, 2007
Grubhead
  • 5259 Answers
SOURCE: teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Posted on Oct 24, 2009
dmftrucker
  • 1922 Answers
SOURCE: the turntable turns very slow when set at 33
the motor needs cleaning,along with the inner shaft on the spindle and a new table belt will help they glaze and slip
Posted on Nov 09, 2009
Grubhead
  • 5259 Answers
SOURCE: How do you adjust the speed of a Memorex 2601M?
Go inside and look at the main board you should see two/three presets, one for 45 and one for 33 etc.
If not look at the top of the motor for a small hole, it might be covered with a label.
Posted on Nov 27, 2009
jmeredith
  • 417 Answers
SOURCE: my Teac sl-a100 record player
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Posted on Apr 30, 2011
Purchase replacement stylus
Look at the cartridge it fits into and enter the model number and make of that into Google and search for that. The stylus will also be found.
Jan 31, 2014 | Teac SL-A100 Turntable
Needle replacement
Just look at the cartridge fitted. It should have a make and model number. Put that into google and you should find a new stylus.
Oct 29, 2013 | Teac SL-A100 Turntable
Need a new cartridge
On the old one should be a number. If you put that into Google then it should find a site that sells them.
Feb 23, 2013 | Teac SL-A100 Turntable
Needle sliding
Going on what little you have written, the most likely cause is a worn or bent needle. http://www.turntableneedles.com/search.asp?keyword=793-d&search=GO is the needle type that should be correct for your Teac SL-A100 Turntable.
Feb 16, 2013 | Teac SL-A100 Turntable
Turntable slows down and stops
If it has a belt drive, the belt has stretched and needs to be replaced.
Oct 07, 2012 | Teac SL-A100 Turntable
AFTER adjusting the speed setting to 33, all the records are playing too fast, they sound like chipmunks. I tried all three settings and while each speed is different from each other they all seem to be...
If it says your speed setting in on 33, than you have a problem with the speed control inside of the turntable, there is not much you can do in that area. 33 is the slowest speed too, so it seems like it is stuck on 45 or 78. Call Teac if you are still under warranty.
May 15, 2011 | Teac SL-A100 Turntable
My Teac sl-a100 record player sounds like a chipmunk
hi,
jm
Apr 30, 2011 | Teac SL-A100 Turntable
The arm and needle just skate across the record?
Either a bad stylus or the weight on the tone arm needs setting for the cartridge used.
May 28, 2010 | Teac SL-A100 Turntable
Stopped turning
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Jan 28, 2008 | Teac SL-A100 Turntable
Teac SL-A100 Turntable Logo
171 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
