Model SL-3 Maytag Neptune Super Stack Washer-Problem, the door will not lock and light not coming on so the clothes will not spin or drain
  • Anonymous Nov 16, 2008
    Me too, I really appreciate any help!!  My clothes are soggy after a cycle and now I see that the locked door light never comes on so I guess it's never really spinning.  Should I check the drain?
    Thanks so much
  • chsix Jan 12, 2009
    I have same problem. Actually had it before back in 2005 - want to say the repairman replaced a circuit board, but can't remember - it was still under warranty then - now I'm not so lucky. Anyone know how to fix this?
  • 109 Answers
SOURCE: Maytag Neptune MAH400AWW
rear tub bearing is going out, must be replaced, causing too much drag. labor intensive repair.
Posted on Mar 30, 2008
dh1200s
  • 335 Answers
SOURCE: maytag neptune fav6800aww wont spin on rinse cycle
With this post I’m attempting to enhance the troubleshooting process regarding dc/UC errors in Spin Cycle associated with the FAV6800A machine. The troubleshooting steps are more to help DIY owners but it could be good info. for other owners to pass along to their appliance repair service if you go forward with a repair. I’m a DIY’er who refused to junk my machine as long as parts cost did not trigger a replacement decision and I have some basic mechanical skills. What I have learned about these fail codes, dc/UC in Spin Cycle is…. this is a chronic failure condition associated with the FAV6800A series machine (no brainer per numerous posts in this forum) and I feel that most of the time these codes are associated with a clutch malfunction.
The troubleshooting guide packed in the console of your machine makes reference to this issue in the Will Not Spin section of the guide and states to replace the clutch. I re-lubed my clutch with WD-40 and I have been working with 30+ loads of varying size with no Spin Cycle errors since early December 08. I and two other DIY forum members found this issue to be a maintenance issue with the clutch, no out of pocket cost for me and I’m sure under $5 for the other two forum members, I had a can of WD-40 in the house. See the links I have attached within this post. There is a description of the clutch removal I did in those posts. I hope this works for others; I’m sure many of these machines head to the curb for bulk trash pickup. Maybe you can extend the service life of your $1K machine if this proves to be a clutch re-lube fix for this issue. Shame on Maytag for not placing a quality sealed bearing in the clutch…. my opinion.
1. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2...
2. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. I need to post step 3 and the rest of this post in a comment.
Posted on Jan 30, 2009
  • 34 Answers
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Posted on Apr 30, 2009
SOURCE: will drain but wont spin
I just had exactly the same problem. It turns out that the washer thought it was "continuously out of balance" because the inertial unbalance switch was not working properly. The way I fixed it was:
1. I followed the instructions to disassemble the Neptune washer found here: http://www.neptunehelp.com/index_files/Page323.htm and then in the control panel on top I found actually a very useful document stored in the control panel itself. It is called "Schematic Mini-manual LED Washer" and it contains a set of schematics for the electrical system and an explanation on how to run various diagnostics on the washer. This was incredibly helpful.
2. I checked the diagnostic code using the following procedure:
a. Plug the washer in for power.
b. Put the washer into "Service Mode" by holding the "Delicates" and "Heavy soil" keys simultaneously for 3 or more seconds. My washer showed a "00" on the screen when it was in Service Mode.
c. Pushed "Presoak" to put it in diagnostic code mode.
d. Pushed the down arrow key to read out the last diagnostic code. In my case the most recent diagnostic code was a "05", which the mini-manual says means "Continuous unbalanced circuit". In fact the mini-manual also says to "Check for: Faulty unbalance switches, Loose wire connections, Bad control board".
e. To find out how many cycles ago this happened, you can push the "Cotton/sturdy" button and it will tell you how many cycles ago this happened. I can't remember the response of my washer, but it either showed a "00" or "01".
To double check the diagnostic code, I
a. Cleared the list of diagnostic codes by holding the "Heavy soil" and "Presoak" buttons for 3 seconds while in the "Diagnostic code" mode;
b. Put the washer door back on and screwed it in without putting the entire front back on the washer.
c. Pushed the "off" button or unplug the washer and plug it back in to get it out of "Service mode".
c. Ran just the spin cycle, where it counted down to 7 and then was perfectly silent and then displayed a "00" without really trying to spin.
Double checking the diagnostic code probably wasnt' really needed, but I thought I would try it just to make sure. I did receive the "05" diagnostic code again.
3. With the washer unplugged again, I did the following to check that the switches were the problem, I checked the resistance of the circuit that has the following three switches in it: the inertial unbalance switch, the low tub displacement switch, and the upper tub displacement switch. If the circuit has effectively "0" Ohms of resistance, the switches are good. If you effectively have "infinite" resistance, then one of the switches is bad.
The mini-manual shows you where the switches are physically on the washer. The easiest way to check this is to find a connector that connects the three switches to the control panel. I found this by lifting the top panel of the washer up all of the way so I could access the top of the washer's tub. Based on the schematic from the mini-manual, the in-line connector has four wires. One side you will find a red wire with the number "23" on it and an orange wire with the number "40" on it. The other half of the connector has two blue wires connected to it, one with the number "23" on it and one with the number "40" on it. In my washer, this connector was placed on top of the washer toward the back.
To test to see if one of the switches is not working:
a. Disconnect the inline connector described above.
b. Test the resistance between the two terminals on the side of the connector having the two blue wires. I found that when I did this I had infinite resistance, so want of the switches was stuck open, indicating the "unbalanced " condition.
To find which switch was at fault, I disconnected each switch from the circuit and tested each one individually. The one that was easiest to get to was the lower tub displacement switch, which is in the front on the bottom of the washer's tub. It worked fine (0 Ohms resistance normally and infinite resistance when you push the button). The next I tried was the inertial unbalance switch, which is placed on the top, right, front of the tub just underneath the block of concrete that is mounted on the tub. For convenience, I removed the concrete block so I could easily access and remove the switch.
This was the switch with the problem (it was effectively stuck open or infinite resistance). It seems to have some rod of metal in it that moves back and forth with the washers motion, so I just shook it vigorously and you could hear the rod of metal move back and forth. This seemed to free up the switch mechanism and the switch functioned again (showed "0" ohms when it was held in about the same position as it would be on the washer). I put the switch back in place and checked the connector with the blue wires leading to all three switches as before. This time I received effectively "0" Ohms, meaning that the problem was fixed.
4. At this point, I put everything back together again (concrete block, reconnected the in-line connector to the switches, and reversed the procedure found in http://www.neptunehelp.com/index_files/Page323.htm ).
Once everything was back together again, I tested just a "spin" cycle and everything worked. You could also test this before putting things back together (probably a good idea) by temporarily putting the door on properly and trying a "spin" cycle.
Another thing to note, you could actually check the diagnostic codes and run several of the tests without taking the entire washer apart. Basically, all you need to do is get the mini-manual out of the control panel (I there are 6 screws total I took off) and run the tests before opening the rest of the washer.
In the end, it might be good to clean or lubricate the inertial unbalance switch or replace it since it will probably stick again. Unfortunately, I am not sure how it is built, so I am not sure what the best way to clean or lubricate it is. Just shaking it for the moment did the trick.
Hope this helps.
Posted on Aug 22, 2009
oldmanewtoys
  • 414 Answers
SOURCE: mah4000aww no door locked light
The lid/door safety switch needs replaced
Posted on Mar 08, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Washers empties water but wont ring out clothes
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Transmission or clutch assembly not engaging due to going out or slipping.
Sep 28, 2014 | Maytag Neptune Washing Machines
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Start button want stay on
this is most likely to be upper control board/located in the top of dryer
Feb 18, 2013 | Maytag Neptune Washer
My washer turns to wash clothes but does not spin to drain water!
does your door-lock light come on, if not than the problem could be there.
Aug 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door lock suddenly does not function when depressing the start/stop button on my Neptune Super Stack SL3 washer-dryer. The locked light is on however. The result is that the washer will not spin or drain.
If you take off the face plate where the knobs are at or if you know how to get to the wax motor you'll find a red solid cable and if you pull this cable it will release the mechanism which is keeping the wax motor engaged
Jun 30, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
Hi, I have a Maytag Neptune (clothes) Washer. The tub didn't drain. Ran it twice. The second time with no soap. The drain pipe is not blocked. The hose is not kinked. I just leveled it because it was...
is the door lock light coming on if so then could be a clogged pump or bad pump. if lock light doesnt come on then may be a bad door latch/lock. may take a minute or two for light to com on once you turn it on .
Sep 16, 2009 | Maytag MAH6500 Neptune Front Loading...
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Detergent goes where?
3 - Select Cycle
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
My neptune does not extract.  My clothes come out dripping wet.
I am having the same problem, and have found that the door lock light is not on, and that the door lock does not seem to be working. This would keep the machine from spinning.
Is your door lock light on?
Jun 14, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Washing Machines Logo
331 people viewed this question
Top Washing Machines Experts
