RTa iNTERNATIONAL propane patio heater
After replacing the propane tank twice,I can"t get it to light
  • 3,037 Answers
Check to see if the valve is opening and whether you here gas running through the system. Have you tried lighting it with a match or do you have a button to press to light it. The button lighter might be broken and would need to be replaced. Check for spark, otherwise I would just light with a match.
Please update me on the situation
Thank you and Good luck
Posted on Apr 13, 2008
  • 796 Answers
May be the pressure is not sufficient enough,,
check for the pipes...
I have a RTA patio heater and on the box says it will work with LP or Propane but in the manual doesnt go into how to hook it or what needs to be done to LP connection can this be hooked into a home supply...
You didn't specify which model you have (Table Top or Tall Patio Heater). In any event, it doesn't matter, as LP and Propane are one in the same. However, it can not be converted to Natural Gas. Rita makes a separate Natural Gas model for that type of hookup.
Feb 10, 2011 | Rta International Patio Heater
I have an RTA International Patio Heater, Model 385.001 with a clogged pilot light valve. I need a way to fix the problem or a new replacement part. I have a commercial gas heating repair company working...
Gas Valves are not meant to be repaired only replaced. So I would have them replace the part and have them warranty there work. If the heater is very old and the replacement part is going to be half the cost of a new one You might want to put that Money on a new one and get a New manufactures warranty in the deal. Just another point of view....... Hope this helps
Feb 07, 2011 | Rta International Patio Heater
Just bought a brand new pre-assembled unit from Lowe's - same problem! Can't get any propane flow through the valve in the normal position. Spent the last 2 hours just getting the pilot light to work -...
Try having all propane turned OFF. some systems auto shut off for leaks. SO....if you have the valve turned on when you open the tank valve, safety systems stop flow.
Dec 25, 2010 | Rta International Patio Heater
I am not getting gas to the top of the unit. How do I check to see if the regulator is allowing the flow of propane?
You will need a Pressure guage or manometer and fit this to the test point on the heater. Normal problems are blocked pilot or main injector blocked
Dec 13, 2010 | Rta International Patio Heater
I have a propane patio heater that is not getting gas to the igniter how do i fix...
I've been told spiders can block outdoor gas lines,try to remove any blockage
Dec 11, 2010 | Rta International Patio Heater
Problem with gas flow?
Could be a couple of things. New regulator, easy fix. If not the regulator, then you most likely have a blockage in the pilot assembly. You have to take apart the head to get to the pilot jet assembly and clear the blockage. If you are not comfortable doing this, hire a service tech.
Nov 20, 2009 | Rta International Patio Heater
My patio heater does not heat up properly
you need to replace the pressureregulater or have it ajust if it is ajustable thanks from gilles
Mar 14, 2009 | Rta International Patio Heater With Table
Bad thermocouple in RTA International Pation Heater
try national energy they do spare s never worked on one fitted one , thermocouples are nornaly just two nuts sorry cant help much more
Jan 22, 2009 | Rta International Patio Heater
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
