Question about Car Audio & Video
700 watts rms
Wold my power acoustik a1000db be able to push two 700 watt rms subs
Yes,should push very nicely. also depending on what kind of subs.
Posted on Apr 18, 2008
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
I have power akoustik 12"
If you sub is dual 4 ohm voice coil, you can get a 4000 watt amp (which will give you 1700 watts RMS at 2ohms). The model number is OW-BAMF40001D. Hope this helps.
Aug 20, 2011 | Power Acoustik Power-Acoustik FUBAR-12W...
I would like to know how watts or rms is it
220 Watts X 2 @ 4 Ohm RMS
• 280 Watts X 2 @ 2 Ohm RMS
• 980 Watts X 1 Bridged Output
• 560 Watts X @ Mono RMS
Sep 12, 2010 | Power Acoustik LT-980/2 Car Audio...
I just need to know the best way to hook my amp and subs together. i like a lot of bass. i just bought the subs and yhey dont really sound any diffrent. should i get a new amp.
Hello hembreegerry,
If you like a lot of bass, you definitely need to consider another amp. The SP2X-300 is only rated at 170 watts RMS into 4 ohms mono. That would barely be enough to power one small sub. You do not specify what brand and model your subs are, their impedance, or their power handling capacity. But for any subs, your best power solution is to add together the individual RMS power handling capacity and select a monoblock amp that provides close to the maximum at the impedance they will be wired to present. For example, if your subs are 4 ohms and have a maximum RMS of 250 watts, you would want an amp that outputs abour 500 watts into 2 ohms (2 4 ohm subs wired in parallel = 2 ohm load). An ideal amp in that example would be the Alpine MRP-M500 which outputs 500 watts RMS into 2 ohms.
Hope this helps.
Sep 10, 2009 | Power Acoustik Sapphire SP2X-300 Car Audio...
Hooking sub up
Hello missywarden,
According to the specifications, the amp is capable of "tri-mode" operation, that is, running normal speakers on the individual channels while also powering a subwoofer in bridged mode.
Your sub needs to be a minimum of 4ohms and should be relatively efficient. I'd look for a sub that has an RMS power range of from about 75 watts up to a maximum of 250 watts.
The sub connects to the leftmost speaker terminal (positive - right channel) and the rightmost speaker terminal (negative - left channel).
It's not going to be a really loud subwoofer. The power is 360 watts RMS which will be shared by the normal speakers and subwoofer.
Hope this helps.
Aug 05, 2009 | Power Acoustik TS620-2 Car Audio Amplifier
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Amp getting really hot
well it is getting hot due to the amp drawing and pushing alot of current. try getting lower gage wiring for power to the amp and lower gage speaker wire.
Apr 20, 2008 | Power Acoustik PS2-1200 Car Audio...
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
