Question about Samsung SyncMaster 750S Monitor
VGA cable pin-outs for a Samsung 750s model code AQ17LS7LK
Seeking VGA cable pin-outs for a Samsung 750s model code AQ17LS7LK
  • Bob Sintzel Apr 13, 2008
    Sorry, but the DB15 image doesn't match what came with the Samsung SyncMaster 750S model AQ17LS7LK
    The 'original' DB15 VGA connector uses the following pins:
    1,2,3, - , 5
    6,7,8,9,10 (ALL 5)
    -, 12,13,14,15
    The original cable contains the following :
    outer shield
    bare ground wire next to shield
    Red wire with bare ground wire both shielded
    Green wire with bare ground wire both shielded
    Blue wire with bare ground wire both shielded
    Orange
    Grey wire with bare ground wire both shielded
    Yellow
    White
    Purple
    Black (shiny)
    I've identified the following from the monitor chassis and a service manual I found on-line, for a Samsung 750S model DP17LS/LT ( I need the pinouts for an DP17LS/LK ),
    RED
    GND-RED
    GREEN
    GND-GREEN
    BLUE
    GND-BLUE
    BLACK with GLOSS FINISH - manual says GND???
    H-IN PURPLE
    V-IN WHITE
    DDC DATA - ORANGE
    DDC CLOCK YELLOW
    S-RASTER GREY
    FLAT BLACK HEAT SHRINK - manual says DDC5V ???
    The manual I have shows pin 9 as N-C, but it is in fact wired on the original connector.
    The grey wire ( S-RASTER) has a bare ground and is shown in my manual as connected to pin 10 along with the ground wire. This seems strange!
    The pins on the diagram you provided use pins that don't exist on the original connector.
    Do you have the pinouts 'specifically' for the Samsung SyncMaster 750S model AQ17LS7LK?
    Thanks for your help
    Bob
  • 47 Answers
Check this out:
http://www.tkk.fi/Misc/Electronics/faq/vga2rgb/vga2bnc.gif
let me know if it helps.
Posted on Apr 13, 2008
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
Vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 16, 2008 | Samsung SyncMaster 750S Monitor
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
1. check tha VGA cable is properly connected into the computer
2. possibly CRT board dry solder. you can touch up the solder joint
Apr 17, 2008 | Samsung SyncMaster 750S Monitor
Still seeking db15 pin-outs for a samsung AQ17LS7LK
Here is the wiring colors for the VGA cable:
1- Red
2- Green
3- Blue
4- NC
5- Gray Shield
6- Red Shield
7- Green Shield
8- Blue Shield
9- NC
10- Violet
11- NC
12- Orange
13- Gray
14- Yellow
15- White
Apr 14, 2008 | Samsung SyncMaster 750S Monitor
Replacing vga cable
A VGA cable is a D-Sub 15 pin cable.
Connector information:
http://en.wikipedia.org/wiki/VGA_connector
Pinning information about midway down the page:
http://myhometheater.homestead.com/vgacable.html
Is that what you were looking for?
Mar 27, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 750S Monitor Logo
425 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
