remove pull cover and check spool if sitting flush ,not broken chipped or cracked ,rope not frayed or jammed,turn spool to retract the rope if no resistance spring either broke or popped out of retainer and further disassembly required caution when doing so spring can still have tension the following link shows different type of pull start problems and repairs Replace Pull Start Cord Yahoo Video Search Results
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
If you are a little bit handy, fo to your auto parts store and get a small fiberglass body repair kit. Read the directions. Make sure you have the edges of the crack smooth and level with each other. Cut a piece of the cloth that comes in the kit that will cover the crack. Carefully mix the resin and hardener that comes in the kit. Then working quickly spread it smoothly over the cloth. Let it set up and sand smooth with 120 grit sand paper. If you want to try to match the interior color of your refrigerator, you could spray paint just the area that you patched.
I'm assuming you already replaced the drum, and are still getting this error? Sometimes the chip in the drum that resets the counter is bad. This is esp. true if you get a reman drum. You should replace the drum and try again to see if this fixes the problem. Go back to the place you bought the new drum from and tell them the chip didn't reset the counter and if it's still under warranty they should replace it.
try this one. right-click on the Google Chrome icon and click Properties. Then go to the Target box and add --no-sandbox after the target and click OK.
For example, if it shows the following in the target box:
C:\Documents and Settings\Rodietom\Local Settings\Application Data\Google\Chrome\Application\chrome.exe"
it should look like the following after adding --no-sandbox to it..
C:\Documents and Settings\Rodietom\Local Settings\Application Data\Google\Chrome\Application\chrome.exe" --no-sandbox
Good luck let me kow if you have sucess i have a phone with cracked screen i gave up an bought another. As far as someone to do it for you not aware, bu thte above link may helpyou.
If it is still under warranty and you did not hit it (no evidence of impact on the outside, the manufacturer should replace it. You might get them ot give you a discount even if it is out of warranty but fairly new. Otherwise, this is not something that cna be fixed due to the way they are made.
