Question about Mitsubishi WS-55513 55" Rear Projection HDTV
LED light flashes
We watched the tv night before got up next day went to turn on and the led light started flashing. after about 3 constant hours of flashing we pushed the reset button. It has now been flashing for 28 hours..... Would really like to be able to turn it on and watch something.. PLEASE can you help
    Genius:
  • 1,694 Answers
Www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp fuses on trace side of DM board.....T.
Posted on Apr 25, 2008
  • 121 Answers
If yellow.. one of the doors is open (lamp or filter door). Red just indicates a major failure. (call service indicated). Sorry, best of luck.
Posted on Apr 22, 2008
  • Timothy Brooks
    Timothy Brooks Apr 22, 2008
    These are known to blow the filter capacitor on the power board. This is not too hard to fix (for the inclined).
Green light blinks 3 times
Hitachi p50s601 led blinks 3 times - YouTube
? 2:22
www.youtube.com/watch?v=xM6bpKK0LG0
Jun 28, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click ... flash, but when I remove both boards the TV just runs agreen solid led as if it .... It would show a static then go right back in the 3 blinking blue lights.
Apple TV: About the status light - Apple Support
https://support.apple.com/en-us/HT200154
Apple Inc.Apr 29, 2015 - The Apple TV status light (LED) glows steadily, flashes, or turns off. ...Flashes three times, Rejecting a command from the remote (you've ...
Oct 19, 2015 | Televison & Video
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
TV was working fine when we went to bed Monday (August 30) night. Got up the next morning and turned it on. It appeared it was going to come on, the green light flashed and then the lamp indicator light...
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A
Sep 08, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Takes to long for unit to come on, when pressing power on remote, green light comes on, but it takes over an hour for the picture to come on.
could be a lamp problem, turn the set off, watch the front led light next to LAMP, count how many flashes in sequence, eg. 2 flashes indicate lamp problem, 3 flashes internal overheat problem. if a orange light flashes next to POWER indicator you have a power malfunction.
Aug 22, 2010 | Panasonic PT-61LCZ70 Television
Panasonic PT-50LC14 HDTV went caput and stopped working
Ur tv LED light indicator "LAMP"flashes?Then the projection bulb life is over must be change.This tv been watching the tv at least 4 or 5 hours a day,the last 3 years?The projection bulb only last about 1500 hours.
May 26, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tv will not start up
does the front led flash. if it doesnt then you may have a primary power problem.. the fuse may have blowed,., this ussally means other componets have shorted IF the led flashes then you have a processor shutdown
Dec 31, 2008 | RCA D52W19 52" Rear Projection Television
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
166 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
