HP Desktop keeps rebooting itself
I have checked the setup to see if the boot order is correct and it boots from hard drive first then CD drive...can't figure it out....
Julie
    President:
  • 2,351 Answers
Hi Julie, the boot order is not correct. You need to change the order to boot to you're cdrom first than to you're hard disk drive.
To change that order go to the boot section of you're bios. Move to select you're cdrom & press enter on the keyboard & a list will open. You cam move devices up & down by pressing the + or - keys. Once you have corrected the boot order save & exit.
As the pc begins to start back up, press the F8 key every 2 seconds. A window will open, look for ( Disable automatic restart on system failure ). Choose the option. Windows should continue to load windows. If you see any error messages write them down & post them here.
If windows does not load continue following as mentioned below.
Check if the PC continues to reboot itself. If it continues to do so than you're windows boot files may be corrupted or worse. Load you're restore cd or you're windows cd into you're cdrom drive & restart you're PC. You should see. to load the cd press any key... (Press the space bar). You're cd will start to load. If you're using windows or the restore cd follow the on screen instruction to reinstall windows (ONLY). Doing a reinstall will not earse you're personall data. Do not format you're drive, (Yet). Finish installing windows. The PC will restart once or twice & you will see ( to load from CD press any key... ) Do nothing, windows will continue installing. When finished run windows update till there are no more updated. Some programs will need to be reinstalled, like printer software.
Post back if you need more help or have questions.
Good Luck Julie!
Mike
How to vote you're expert & repost questions.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Posted on Apr 13, 2008
  • 47 Answers
Probably a RAM problem, but need the error message to confirm.
Pls reply back with the same.
What can I do to fix this problem, my gr 500 is telling me to reboot and select proper device or insert boot media in selected boot device
You need to go into your Bios or System Setup and change the boot order or boot sequence. It sounds like you might be trying to boot from a Network or Lan. It could be that you are trying to boot from the CD drive but instead of having a operating system disc in the drive you might have a movie or music cd in the drive.
Reboot the computer and notice what key the screen says to hit to get into the Bios or System Setup and hit that key. Change your boot order or boot sequence. The best sequence is to have the CD Drive 1st and the Hard Drive 2nd. Changing this in the bios or system setup will make the change permanent. Just make sure when you boot the computer that nothing is in the CD drive unless you have a repair disc or operating system disc in it.
You could make a temporary change but then you will have to change it every time you boot. If you notice the screen when you boot it also gives you the key to hit to change the boot order or boot sequence. This will allow you to change it just for this time that you are booting.
May 03, 2012 | Gateway 500GR PC Desktop
My asus desktop with windows vista will not start up. I keep getting a black screen that tells me reboot and select proper boot device or insert media? What is wrong?
It means your system is trying to boot from somewhere other than your hard drive. Make sure you don't have a CD in the CD/DvD Drive. Also when you boot your system pay close attention to which key it says you can hit to change the boot sequence or boot order and which key it says you can select to go into the Bios or Setup. Boot the system the go into the BIOS or Setup. Go to the tab that allows you to select your boot order. Make sure your Hard Drive is selected as the first boot device. Try rebooting after saving and making this change.
Mar 17, 2012 | ASUS Computers & Internet
Carresearch, I just put the cd in and restarted the computer but the reinstallation didn't start. How do I reboot the cd first?
OK, Here's what you need to do. Shut down the computer. When you restart it, as it boots, continue to press and release the F2 key as the computer starts up. When it does, you will get a BIOS setup screen. From there, there will be an option to change boot sequence. Make CD drive first and then C: drive. Save your changes and then reboot. This time, the computer should load your reinstall disk. Let me know how it goes.
Apr 03, 2011 | Dell DIMENSION 3000 CELERON 2.4GHZ...
How do I fix or repair my HP mini 1000 Netbook with it being stuck in a boot loop? I am getting the "unmountable_boot_volume screen. My netbook does not have a CD ROM drive.
Check your bios to ensure its first boot option is set to the hard drive instead of CD drive or USB drive. If you have a thumb drive plugged in, unplug the USB and try again. On your boot screen there should be an option to hit a key to enter bios (Usually Esc, F2 or Del). Hit whichever key it requests and enter Bios. Once in Bios look for Boot Order and check to see where the Hard Drive is in the order. If it is not set to #1 then do as it says to set it to the first option. Once done hit F10 to save and Exit and return to boot.
Feb 04, 2011 | HP Mini 1000 Netbook
I have a dell 5100 desktop. I want to reinstall windows, but it keeps looping back to set up installation. Please advise
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu.
When you have changed that, insert that Bootable Disk you have made in the Drive, and reboot.
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Oct 24, 2010 | Dell Computers & Internet
Was installing hp starter disk 6500 into dell4550 dell was terned off my mistake and now wont re-boot just blank screen with small light flashing were fast upper left corner of screen
Enter the system bios and set the boot order to boot from CD ROM. If this order is correct and you are still experiencing the same issue. Re-enter the bios and set it to default setup. However, enter the boot order and ensure the CD-ROM is the first boot device and Hard Drive is the second.
Enjoy the power of a PC
Mar 13, 2010 | Dell Dimension 4550 PC Desktop
Computer has a virus. Want to format drive and reintall windows but when I try to read cd off of desktop the pointer becomes busy and sort of freezes any operation.
If you plan to reformat the hdd, just boot the unit off the cd. you may have to go into the BIOS setup and change the boot order so that it accesses the cdrom first. In most HP systems you can access the BIOS setup by hitting f10 key during the boot stage.
Oct 04, 2009 | HP Compaq Presario SR1830NX PC Desktop
I can not get the CD window to operate on my computer. How can I get it to open.
I suppose you are talking about the cd Drawer itself.
You can mechanically open it by inserting a paperclip wire through that tiny hole found on the front of the CD drawer or flap.
A slight pressure will release the latch.
THIS is done WITH THE POWER OFF.
Rather like when you poke your fingers through the grill of a car to release the secondary safety latch.
Regards
Apeal
Aug 21, 2009 | Dell Hp Pavilion Slimline Computer s3710t...
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
Computers & Internet Logo
1,283 people viewed this question
David Payne
David Payne
