Question about Tappan TGF320 Gas Kitchen Range
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
It's beeping. I believe it had F1 displayed in window. Pushed all the buttons but cant stop the beeping and the display doesnt change.
The stove is about 9 years old but like new. It's our second stove in the lower walk out and used one hour a year.
Help
Carl
  • chantymer Jun 01, 2008
    I was wiping the stove and the back part and all of a sudden the timer started beeping and we can't get it to stop without unplugging the electrical supply. The only problem is that the stove has electronic ignition for the oven and burners. Help!
  • 794 Answers
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
May 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
GE Gas Stove'Error msg. F1"
Look in the back of the stove for a tech sheet. It should say on there. If I'm thinking of the right one, I believe it means the keypad is bad. Let me know what you find and I can help you further.
Mar 29, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Sep 18, 2008 | Kitchen Ranges
F1 and F2
depends on the brand, most of the time its an erc (electronic range control) this can be replaced. find a appliance store near you, give them the model and ask for the price and availability of an erc. If satisfied call a tech. If a tech installs it you have a warranty... get the picture?
Feb 08, 2008 | Kitchen Ranges
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Stove Glass top
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Thanks
Oct 22, 2007 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Oct 16, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Magic chef stove
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
Oct 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
259 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
