Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Intermitten power poblem
I have a 2000 heritage that sometimes looses power and shuts off can happen at any speed, starts right back up, speedo ood stop working and engine light comes on
    Scholar:
  • 150 Answers
Ok the twin cams have the brain located right under the seat. think about it, brain **** proximity issues here bro but not to worry it's harley who had their head too close to their **** anyhoo check the connections at the wiring harness to the module for corrosion or otherwise nefarious condition and I bet you get it licked
Posted on Apr 18, 2008
How to replace speedo cable 97 hertiage softail
Hi Lujan4263, 1997 FLSTC do not have speedometer cables they the speedometers are electronic and have a speed sensor located on top right hand side of the transmission between the top cover and the chrome starter end cap. Good luck
Apr 12, 2013 | 2007 Harley Davidson FLSTC Heritage...
I have a triumph daytona 650 speedometer problem
Sorry I don't have a solution, but I have a similar problem. At idle, I run about 14.2 volts and it stays that way up to around 5k, don't go higher in my garage. Anyway, my problem is when my fan kicks on. I have seen my volts drop into the low 10's when fan kicks on. If it is hot out and I am in dealing with lots of stop and go traffic, my fan will kick on a few times...normal so far. But, if this happens too many times without a good stretch of riding in between, my speedo will kick off or go to 188 on the gauge when the fan kicks on. As soon as I pull out the RPM's increase and all is well, but sometimes, I will actually loose my speedo all together. If I shut the bike off for a minute then start it back up, the speedo works fine. Any ideas???
Apr 05, 2010 | 2005 Triumph Daytona 650
My speedo on my 1993 dodge cummins quit working, i use to be albe to get up to around 80km/hr and it would work again. also my overdrive doesn't work when i speedo isn't working. any ideas.
I am no expert on this but have the same problem. Here is where I am at. I bought the truck used, needed a new PCM which after installing one from a gas job and verifying that wiring was good, bought a reman from Chrysler. Speedo still did not work even though it did with the gas PCM but was fluctuating allover. Chrysler replaced PCM and speedo started to work intermittantly. Took truck into dealer and $600. later told mechanic thought it was faulty PCM. He called Chrysler and asked them to pull one from the shelf and test. They said needed a new crankshaft speed sensor.Mechanic took truck on the road, shifted into nuetral then turned ignition back on, speedo works. Replaced crankshaft speed sensor and situation didn't change. Total spent $1000. and no speedo and no overdrive. Speedo started working intermittantly, seemed like depending on transmission temperature. Friend that works on dodge said is instrument cluster. tried another cluster still the same. Replaced ignition switch, thinking that may be the problem. Still the same. Bought a new Neutral starting switch, which I have not replaced as of yet. If I place truck in neutral and start the truck speedometer is activated right away but does not stay. So right now am down to two scenarios. The neutral starting switch or,...... the temp sensor in the oil line. Feeling is it is the neutral starting switch. By the way had already replaced speed sensor in tranny and rear end. Going to replace neutral starting switch, cost is $25. for the part and see what happens. Please keep us posted, as others are having the same problem.
Nov 12, 2009 | 1993 Dodge Ram
Recently I changed my honda civic 2000, no tachometer speedcluster by one who has tachometer. The change was without any problem until recently started having problems with the speedometer, and that...
Souds like the speedo cable / speed sensor has come loose at the back of the gauge cluster. Common problem easily fixed. Make sure it clips in fully next time.
Sep 15, 2009 | 1996 Honda Civic
01 heritage. Engine light comes on, odometer goes blank, speedo freezes or goes to zero, bike still runs. Loose connection? Short?
yes thats a good place to start-always check wiring 1st-sometimes things that appear normal can be corroded but i think your alternator battery or regulator is failing-test it dew u have a manual!!
Aug 05, 2009 | 2001 Harley Davidson FLSTC - FLSTCI...
When I ride my 2000 fatboy my speedometer doesn't
Try inside the tach on the connector. But also remove your speed sensor on the transmission and clean it. They pick up metal chips from the trans and short out. Also, HD had a bunch of bad speedos around your year. They replaced them for free. Doubtful they will replace yours at this late date. You might end up buying a new speedo.
Jul 16, 2009 | 2000 Harley Davidson FLSTC Heritage...
Speedo sometimes failed to work
I had this exact problem on my old focus. Its nothing to worry about and its not expensive. Your car has a speed senser underneath the gearbox and a common fault on these cars is for the gearbox to slightly drip oil. When the oil drips it drips right on top of the senser and blocks the speed readings.
The good thing about this is your milage on your car wont go up when the speedo stops working, so when you come to sell it!!!!!!! you get my point.
to fix this problem it cost about £20 if you do it yourself.
Feb 18, 2009 | 2000 Ford Focus
Lands Phones Logo
101 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
