Question about Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator
Innovage Phone I got my phone and it did not come with manual. I need to know how to program it to ring more than twice. When I hit the set button and a number nothing happens.
  • 1 more comment
  • Anonymous May 10, 2008
    srfsr
  • Anonymous May 17, 2008
    LCD Touch-Panel Phone- Need Owners Manual
  • TheBikerBrok May 21, 2008
    No Instructions, and the LED Read-Out is Not ledgible?
    Pete Val
    PeteValletutti@yahoo.com
    972-200-5544
I have a phone and cannot change the time from military to 24 hours
Posted on Apr 19, 2008
  • 14 Answers
I got this phone with no user manual, too, so I'm still trying to figure it out. I did manage to change the time from daylight savings to standard after several tries. You just have to keep pressing the set button before it responds at all. Once it does, it will eventually scroll through to the item you need to set. Press the plus and minus keys to change time/date up or down, or to toggle between 12h and 24h (military time), etc. Thanks spiritsoul for the link to the manual. I'm going to check it out now.
Posted on Jan 30, 2010
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
Innovage lcd touch panel phone
hi found a link to a user manual, its very hard to read it, very small writing and not to clear but got basics of phone working, still need to find a hard copy of user manual thx
Jun 23, 2009 | Innovage Speaker/Caller ID* LCD Touch...
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Changing settings on innovage telephone
hi big al,
on my phone you hit SET/SAVE, press UP/DOWN to find the function you want, press SET/SAVE again to select, press UP/DOWN key to program. press SET/SAVE to confirm. i can email you a copy of my manual if you'd like. my email is all8upinwv@yahoo.com hope this helps.
tammy
Apr 19, 2008 | Innovage Speaker/Caller ID* LCD Touch...
Volume
hi pkeyes40, my phone is a differenet model number, but on my phone you raise the volume by hitting the hands free button, then press the delete button several times to adjust the volume ( 1-4), then press the hands free button to confirm. then hit delete to exit. hope it works the same for your phone. good luck. and if you would like me email you with the manual i have for my phone, an innovage lcd phone/caller id 1507102, it might give you some pointers. my email address is all8upinwv@yahoo.com
email me and i reply with the manual. hope i helped ya out. good luck.
tammy
Mar 27, 2008 | Innovage Touch-panel Phone 1502084
Innovage (1604007) Corded Phone
Here is the fix for that problem...
1st click the set button on the bottom left of the keypad. Press the "up" button (located to the right of the the keypad) until you get to option number 7 IPP. Click the set button again (so you can change the settings for that option) and press the down button to turn off the option. Click the set button one more time and finally press the delete button to get out of your settings mode. No More beep, beep, beep......
Hope This Helped--WICC-
Feb 07, 2008 | Innovage 1604007 Corded Phone
Innovage LCD panel phone -product ID# 1507102 direction manual
this is the manual for model # 1507102...found one and thought i'd share...didn't realize how lucky i was to have one in my box... ok well i am having a hard time loading it..those with email addresses i will email you a copy . in the subject line it will say "manual for #1507102" so be sure to open it. it will be from all8upinwv@gmail.com thats me...tammy. sorry i couldn't load but will try again later. feel free to email with a question and i'll send you a copy of manual.
Sep 06, 2007 | Innovage Touch-Panel Phone 1507102
Setting up ring tone
When the phone is sitting in its normal mode hitting the "flash" button toggles through the available ring-tones, including my favorite: off
Jun 11, 2007 | Innovage Touch-panel Phone 1502084
Pre-set dial numbers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Mar 31, 2007 | Innovage 69420210126 Phone
Innovage Speaker/Caller ID* LCD Touch Panel Phone with 12-Digit Calculator Logo
396 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
