Question about Metz 45 CL-1 Flash
Metz 45CT-4 power output
My unit only operates on full power with no automatic operation. I can hear the unit pop on full power and I do not have any automatic correct exposure indicator operation
Thanks
  • Anonymous Dec 21, 2008
    CL FLASH WORKING ON ONLY MANUAL
  • ellinuxero Mar 31, 2009
    I have the same problem. No auto, no M/2, no M/4, no Wind. Always operate at full power. I think it's not "an auto mode problem" because no Manual/2, Manual/4 works (wind neather)
    New Friend:
  • 30 Answers
Have it serviced, or sell it. The culprit of this malfunction is either a faulty quench capacitor, of high capacitance and voltage, but small physical size, or a thyristor. Both are made of "unobtainium", can only be cannibalized from organ donors.
Posted on Dec 08, 2008
    Problem Solver:
  • 9 Answers
Batteries is necessary for multi mod, full power only for power pack(Quantum etc) connection without batteries installed.
Posted on Dec 10, 2010
Metz CT-4 flash gun overheated on the shaft the plastic casing overheated and melted the plastic on the handle grip I opened it up and noticed the wires inside were completely Melted.
Unfortunately, from your description, the flash is completely done for - while a repair may be possible, I doubt if it would be economically worthwhile. Replacement is probably the only answer.
What may be more important is to find out why this occurred - is it down to the charger, the batteries or an internal problem with the flash ? Were the batteries those supplied by Metz, or a different make ? If they were Metz ones, then maybe you should inform the manufacturers, to help others avoid this problem, and you might get a replacement flash if it is a manufacturing problem.
Jan 13, 2016 | Metz Cameras
I've had 2 Metz 54MZ4 flash units with my Canon 1Ds and 10D cameras and none of them work in TTL mode. They give full output power in TTL. What is problem?
If your Metz is for Nikon it will not work in TTL on Cannons. Metz makes different flashes for Nikon and Cannon. I have a Metz 54 that I use with my Nikon D200 and it works as well or better than the NIkon SB800 in TTL.
Jun 04, 2010 | Metz 54 MZ-4 for Nikon TTL Flash
Metz 45 CT-1 Outup Calibration
During the flash impulse the "photocell", actually a phototransistor, charges a capacitor with current, proportional to the reflected light intensity. As soon as the voltage on that capacitor reaches the trigger voltage of a four-layer diode (which, in fact, is playing a role of a PUT) that turns on and triggers the quench thyristor. There is a trimmer potentiometer in the four-layer diode circuitry, which sets the trigger voltage. You can try to fiddling with that. But the culprit of the misalignment easily can be in any of the parts in the above described circuitry.
May 18, 2009 | Metz mecablitz 45 CL-4 TTL Flash
I have not used my Metz 45ct-5 flash for over a year.
You may have to install new batteries, a few times. The Capacitor will **** the life out of the batteries as it builds up its charge. I have a Hasselblad D-Flash 40 this happened to. Bought as Mint. Not used in over 1 year. When I received it, I was absolutely pissed that I bought more ebay junk. But, I persisted. I think I went through 30 batteries, before the Capacitor rejuvenated itself. Try. Best of luck.
Apr 05, 2009 | Cameras
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz 45CL-4 Service Manual wanted..
Hi !
Here is a link to the Metz manufacturer:
http://www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
I hope it will be to some help.
Regards Lars
Jan 27, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
Contacts voltage
Originally the 45CT1 had high trigger voltage. In the production period Metz improved it to a much lower voltage release circuit. Metz homepage (metz.de) holds the information, from which serial number on have 45-CT1s low trigger voltage. However, even the high trigger voltage was lower than 200 volts, thus safe for your Fuji.
Laszlo
May 03, 2008 | Metz 45 CL-1 Flash
My Metz 45CT-3 is firing at full power no matter what setting is used.
You have shorted wires inside of the flash.
Would you like to see if you can repair it yourself?
atdlee@netzero.com
Mar 07, 2008 | Cameras
Metz flash gun
Is this a 45CT-5 flash?
atdlee@netzero.com
Feb 17, 2008 | Cameras
Metz 45 CL-1 Flash Logo
619 people viewed this question
Top Metz Cameras Experts
Doberman
Neil
Level 1 Expert
Are you a Metz Camera Expert? Answer questions, earn points and help others
