Question about MPC Computers Envision EN 5200e 15"Flat Panel LCD Monitor
Envision box not getting any sigal on the set
    Scholar:
  • 134 Answers
Try to read this article http://www.cas411.com/ShowArticle.aspx?ID=76 , could be your pc trying to display a resolution that your monitor cannot handle
Posted on Apr 16, 2008
Monitors
How to Fix the Resolution on Envision Computer MonitorsXll.jpg"> TS Jordan
TS Jordan is an Ohio licensed attorney living and practicing out of the Cleveland area. In addition to his Juris Doctorate, he holds a Bachelors' Degree in Information Systems. He has been writing professionally for less than a year.
By TS Jordan, eHow Contributor
Envision flat-screen computer monitors come with a "native" resolution, which is the resolution that exactly matches the number of pixels included on the monitor. Setting the resolution to the native standard will therefore produce the best image quality. You can utilize the display properties tools in your computer's operating system to fix your Envision monitor's resolution.
Read more: How to Fix the Resolution on Envision Computer Monitors ' eHow.com http://www.ehow.com/how_6666424_fix-resolution-envision-computer-monitors.html#ixzz2DLKKQZ4M
Nov 26, 2012 | Envision Computer Monitors
My monitor has Out of Range across center and there is no sound how do I get rid of it. It is an Envision monitor
The resolution that your computer is set for is higher than your monitor will support, You need to start the computer in safe mode (F8 on startup) and set the resolution for a much lower one, then restart as usual and set resolution to suit your monitor
Mar 05, 2012 | Envision Computer Monitors
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computer Monitors
I work from home, have a company laptop and use the envision monitor for a second screen. It has an 'out of range' message in the middle of the screen. This happened a long time ago and somehow I was...
It is telling you taht the laptop video resolution feeding it is too high for it to display, you need to set it to the native resolution of this ENVISION monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Feb 02, 2011 | Envision 19" Widescreen Flat Panel TFT LCD...
Input not supported
The repair shop set the PC video resolution to higher resolution to use with their monitor and did not put it back to the same resolution for your monitor which cannot handle the higher resolution. You need to lower the PC video resolution to the native reslution of your monitor which is 1280 x 1024 @60 Hz.
http://s807.photobucket.com/home/budm/allalbums
Jul 14, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
Envision 19" widescreen
You can go to the Envision customer support website and look for the driver under the driver support section for you model monitor. The website is. www.envisiondisplay.com. You can also call the Envision customer support at this telephone number. !-888-838-6388. They should be able to help you with getting the correct driver to support your set-up. I hope this information helps you with your problem.
Dec 27, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Dim display monitor
Scan rate off the charts?
My guess.. Your PC is overdriving the monitor and it is protecting itself from harm.
Startin SAFE mode (press F8 wile booting) and SAFE mode to see if it worksin Windows DEFAULT setting. Then Reboot and readjust to somethingsensible (1280*1600, 32bit, 60Hz)
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto mfg and DL and reinstall the correct drivers again, If this doesn't fix it, then the LCD inverter and Tube are on the way out. You can get parts to fix that here:
LCD Repair and Cable parts
Universal LCD and Inverter Parts
Good Luck!
Dec 25, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Color calibration Envision 17" monitor
Return to dealer for service, This is a common problem of a bad backlight on LCD Monitors. If it is on the top comming down it is the top lamp,from bottom up is the bottom lamp. Hope this helps you .
Dec 17, 2008 | Envision EN-7100e 17" Flat Panel LCD...
All pictures appear wider than they really are
You may have to match up the video card settings with the monitor settings to get the correct resolution setting. Try adjusting the resolution of the graphics card to match the setting for the monitor. If this does not work you can call, Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you get the correct setting for you set-up. I hope this information helps you with your problem.
Dec 03, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
MPC Computers Envision EN 5200e 15"Flat Panel LCD Monitor Logo
183 people viewed this question
Top MPC Computers Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a MPC Computers Computer Monitor Expert? Answer questions, earn points and help others
