Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
I would check the remote control by taking it out of the room first. If that is not the problem, it is likely to be a dry joint in the power supply that is "arcing" and causing this problem. Re soldering the heavy components on the power supply board may fix it.
WATCH OUT FOR CHARGED UP CAPACITORS - THEY ARE LETHAL WHEN CHARGED!
Without more information, it is difficult what to tell you. It is not likely to be something as simple as a fuse. A common failure is the horizontal output transistor if it is a CRT based set. There are other common faults as well. Try turning on the set and report here any symptoms you detect. For example, is there a standby light? Does it blink? Do you here a click when attempting to start the set?
Try to provide answers to the above and I should be able to give you a better idea.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
i think line out put transformer is leaking high voltage.if u r nat an technetion then dont try to on tv agin because high voltages can damage several costly ic in the set.
