Brother MFC-8820D ERROR 6C ON UNIT DISPLAY CALL BROTHER
    Genius:
  • 3,422 Answers
HI,
Try doing a hard reset by unpluging all the cords from back of the printer for 30min. and then plug it back.
Also can you please give more details on your problem so that i can help you fix it.
Posted on Apr 13, 2008
    President:
  • 1,944 Answers
Did you try disconnecting the printer from the power to reset?
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC 8820D Error Message "MAINTENANCE 7". Error Message "CHANGE DRUM" drum and toner changed. I have gently blown out any dust. There seems to be a burning smell when the...
Hi Erika:
A burning smell presents when paper is stuck on the fuser (The hot thing that heats the toner to the paper.) I would take out the drum, and peek in the printer with a flash light and see if you see any paper stuck anywhere it does not belong. Usually, the paper will be burnt "Brownish" in color.
With the drum, there are contacts on them. Make sure they are clean; and do not have toner residue on them. Easy to clean with a pencil eraser. Gently, rub the eraser over the metal contacts to clean off residue. Hope that helps you. If so, please leave me positive feed back.
Aug 04, 2011 | Brother MFC-8820D Laser Flatbel...
Maintenance error 7 on a mfc 8820D
Thank you for posting to Fixya.com and it is my pleasure to guide you.
I have scanned through the appropriate sections of the
Brother MFC-8820D User Manual & Brother MFC-8820D SERVICE MANUAL
and find no referance to a "maintenance error 7". Please include any and all messages given on the panel LCD!
Please press the reply button and I will check back tomarrow.
It is always a pleasure to help!
Jun 15, 2011 | Brother MFC-8820D Laser Flatbel...
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Jun 18, 2009 | Brother MFC-8820D Laser Flatbel...
Poor printing quality after replacing drum
Have you checked to see if your setting for color is set to grayscale?
May 07, 2008 | Brother MFC 8820D All-In-One Laser Printer
ERROR 7A
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Brother MFC-8820D Machine Error A
Oct 02, 2006 | Brother MFC-8820D Laser Flatbel...
78 people viewed this question
k24674
