Question about iLO (2 GB) MP3 Player
Black screen said to format to fat16 i think it was, downloaded software long ago forgot what, installed it, now its a black screen, when i connect usb to it, computer wizard comes any answers, thx.
  • 88 Answers
Go To My COMPUTER right click on your mp3 player removable disk format it
use file system > fat and click quick format and format it
Tanx Bye Take care....
Posted on Apr 17, 2008
How do I get my USB in my vehicle working again?
You might want to try connecting a USB memory stick / thumbdrive formatted differently than is current. Some choices are FAT16, FAT32, NTFS, exFAT and others still. Your computer may recognize several of these - but car manufacturers usually aren't quite as up to date as computer / software companies.
If you're using an unsupported format on a thumbdrive - it may not recognize it. If you're using the USB for a different device (tablet, cellphone, charger, etc.) check to see if the connected device reports power present - if not - no amount of trying with various formats will get it to work. You'll need to address the lack of power at the USB first. Check your owner manual for the location of the fuse(s) that provide power to the USB ports.
Dec 03, 2014 | Office Equipment & Supplies
The wireless connection option is grayed out on the network configuration screen. How do I enable this? Is wifi built-in? If not, are there specific USB wifi adapters that are compatible?
I do not know the specs for the RCA BRC11082E blu-ray player. However, the RCA BRC11082 blu-ray player does not have a built-in wireless option. It has a wired LAN port. No wireless adapter will work in the USB port. It is a good idea to install a flash drive (FAT16 or FAT32 format) to buffer internet content when downloading BD-Live content.
The manual for the BRC11082 is available here: .
I hope this helps and wish that I had better news for you.
Dec 26, 2011 | Televison & Video
It comes up with error code FAT16
fat16 is the type of usb formatting your device should have, what you should do is plug your device in go to computer right click the name of the device and click format that select fat which is fat16. that should fix your device.
Feb 15, 2011 | Memorex MMP8564 MP3 Player
Nikon D70s will not format CF card. Have tried different cards with same result. Connected the camera to PC with card installed but PC says no card installed. Is this a firmware problem?
Go into your menu and change the USB connection from PTP to Mass Storage, Then connect to PC and try formatting. be sure to use FAT16 and not NTFS.
Oct 24, 2010 | Nikon Cameras
I put my SD card in but nothing happens. I've double checked that the card contains picture files using a 24 in 1 USB Card Reader. I'm using a Kingston microSD with adapter. When I take the SD card out of...
Check the way the SD card was formatted. FAT16 or FAT32. Save the images out to the computer, Reformat the SD card to FAT32, add the images. If that doesn't work, do the same with FAT16.
Dec 17, 2017 | Matsunichi 8 digital picture frame
Reformating the internal media to fat16,how?
Go to the Mymusix website and download the player update utility (located here: )
install it, then use these instructions, but start at step 9.
I never got it to actually complete the update process, but it did format it, which solves the problem. Hope this helps
Aug 09, 2009 | MyMusix PD-6070 MP3 Player
The internal media need reformatting
You need to reformat the player for your computer to recognize it. since its requiring the device to be formatted to FAT16.
Hope this helps
Nov 14, 2008 | MyMusix PD-6070 MP3 Player
New songs= black screen
try to remove the battery, wait 30 seconds and replace it
this should reset your sansa,
a real hard reset isn't possible,
you can format it though
warning, this removes everything
To format your Sansa E200 series MP3 player:
1. Open "My Computer."
2. With the player plugged into the USB port, right-click on the player (if in MTP mode) or the drive letter for your player (if in MSC mode) and select "Format" from the right-click menu.
3. Press "Start."
4. You will receive a warning that the format process will erase all data on your device.
IMPORTANT: Make sure you have backed up all of your data from the device before continuing with the format. Procedure will erase everything off the player. Agree to the warning.
5. The format will complete. Close the format window and your player should be ready to use.
After the format, please install the latest firmware update for your player. Please visit the following link to download and upload the Firmware on your Sansa E200:
PLEASE NOTE: All files will be deleted. Backup your files. Your MP3 player must be in MSC mode before installing the Firmware update.
To set your player in MSC mode, please do the following:
1. When the player is turned on, press the “Menu” button.
2. Navigate to the “Settings” menu.
3. Navigate to “USB”.
4. Under the “USB” menu, go to “MSC”.
After changing the player to MSC mode, reconnect it to your computer. The screen on the MP3 player should read “USB Connected” and "MSC”
You can now complete the Firmware update download from on your device.
Installation Instructions:
1. Unplug any other USB flash drives that's connected to any of your USB ports.
2. Download the firmware to your PC
3. Plug in your e200
4. Double-click on the downloaded firmware (e200fw01.00.12.exe) and follow instructions
5. Unplug your e200
6. Device will do it's own update process and will restart.
The device should be ready to be used again.
Dec 16, 2007 | Audio Players & Recorders
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
