Question about Cell Phones
HOW DO I CONFIGURE THE INTERNET CONNECTION PROPERLY ON A SAMSUNG BLACKJACK CELL PHONE
  • 983 Answers
To connect to the internet & to send & receive mms messages you must activate the GPRS first from your network provider ...The best thing you can do is to contact the customer care of your network provider and ask for the activation of GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you will receive the gprs settings(profile) also ... make sure of the charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if the customer people tell you that your handset is not compatible then you must tell to give the manual settings(includes ip address,APN,etc) so that you can only create the profile and input the information given by the customer care people...
any further doubts reply me
i am always here to assist you ..
thank you
bye...
Posted on Apr 13, 2008
How to save phonebook of Samsung SCH-B559 in Desktop Computer
Buy the Samsung OEM data cable along with the ActiveSync install CD. These are purchased together as a set from a reputable cell phone dealer . Enable your computer to access transfer data from your computer to your Samsung BlackJack cell phone by installing the ActiveSync CD. Before installing ActiveSync make sure all other programs are closed.
  • Insert the OEM data cable to your Samsung BlackJack cell phone.Plug in the other end of the OEM data cable to your computer using the USB port.
  • Watch as transfer begins automatically with the ActiveSync program. This will transfer your stored phone numbers from your computer to your Samsung BlackJack cell phone.
    End the ActiveSync program by closing the window. Open the contact information in your Samsung BlackJack phone to make sure all information was transferred.
  • Regards
    Jun 27, 2011 | Cell Phones
    I need to use this phone as a modem for internet. How?
    • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
    • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
    • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
    • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
    • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
    Feb 04, 2011 | Samsung SGHE250i Cell Phone
    No internet connection
    Problems that can cause this problem are :
    - gprs and wap configuration was not right or not activated. Some provider of SIM card require activation via message to send activation setting to your phone. After this activation, phone usually can connect to internet automatically.
    Some of SIM card will configure this setting automatically after put in a phone, but other SIM card need manual configuration. Make sure you've configure internet connection in your phone properly.
    - another problem is signal strenght or continuity. If you make a connection in closed building or other place with low signal, you may can't connect to the internet.
    Hope this help and be kind to rate please, thank you
    (^_^)
    Jan 07, 2011 | Nokia 5230 Cell Phone
    I cant upload photos to facebook from my samsung jet
    there is an application on your samsung jet which is called community. run this application and select account manager on its settings, and configure your fb account. once configure, try to verify it by running verification, once verified, you may start uploading photos. also, consider, configuring your facebook mobile account on your facebook settings. check your internet connection if its configured properly too.
    goodluck
    Jun 05, 2010 | Samsung Jet S8000 Cell Phone
    Can i chat using my blackjack without having to log in to tha internet?
    SMS (texting) and Chat are generic terms for two different means of communication from your phone.
    When you "text" the message is sent to the receiving phone much like a regular phone call "over the air" cell to cell....It has nothing to do with the internet. When you chat you are using a software program and the internet to transfer the information from one phone to another. The term "chat" suggests yes you have to have an internet connection and will probably need a data package from your carrier as well.
    Jul 07, 2009 | Samsung BlackJack Smartphone
    Connection to wifi internet
    Try a new partnership with your pc and and use active syn to update your phone.
    Under connections you'll find wi-fi in theresomewhere and choose it as default connection and you should be good to go.
    Hope this els,
    Steven John
    Nov 27, 2008 | Samsung Blackjack SGH-I607 Smartphone
    Blackjack data connections
    go to menu in the internet explorer, click on tools, click options,click connections. unck the box that says auto detect settings and make sure your connection type is WAP Network
    Jun 23, 2008 | Samsung Blackjack SGH-I607 Smartphone
    Gprs settings for samsung blackjack
    there's no way that you can set it to connect to your service provider especially if you upgrade its software to 6.0 version
    yes you can make the mms settings work but not the internet capabilities of your phone
    Mar 26, 2008 | Samsung Blackjack SGH-I607 Smartphone
    GPRS setup for Samsung Blackjack i607
    Start--Settings---Connections---GPRS
    Click at menu---New--- Connection name
    Connects to The internet
    access point name as provided by Tele provider
    user name and password as by provider
    ip address: as by provider
    done
    go to proxy
    Connects from The internet
    Connects to WAP network
    proxy:port
    type : http
    Username and password as by provider
    Kayshan98
    Feb 03, 2008 | Samsung Blackjack SGH-I607 Smartphone
    Internet problem
    Error Your Internet connection is not configured properly. Please verify your settings in data connections.
    I can't find data connections?
    Feb 02, 2008 | Samsung Blackjack SGH-I607 Smartphone
    Cell Phones Logo
    223 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
