Programming i cant change my tv from air to cable on the menu screen
  • dixietigger Apr 13, 2008
    just bought misubishi tv blue screen comes up ask for code is there a way to reset so i can setup catv function
    Sergeant:
    Champion:
  • 375 Answers
Look in your owners manual for parent lock and front control lock turn them off and set aotoprogramed again.
Posted on Apr 13, 2008
Tv change from air to cable
Have you tryed to go in to your TV menu and look for cable setup. Then change it to cable Not off air... Hope this was helpful.
Jun 02, 2013 | Broksonic Televison & Video
Do not have set up or tuning instructions
Go into the menu on the TV and look for a selection that says auto setup or auto channel scan. Once you have an over the air antenna hooked up to it then run this feature. It will automatically pick up the over the air channels. Also check in the menu and see if there is a selection that says cable/over air. You should be able to get to the menu thru the TV remote.
Dec 17, 2012 | Televison & Video
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
CANT CHANGE FROM AIR TO CABLE
go in to ur menu and use the volume and channel buttons on the TV and it will change fron air to cable
Apr 09, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Menu feature on pltv-3750 is not functioning on dtv source.
ATSC is not a cable tuner, it is for antenna only. Qam tuner is for HD cable. If you dont have a QAM tuner you need a cable box.
Feb 24, 2009 | Protron PLTV-37 37 in. LCD Television
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Cant access "Antenna" in tv menu to change to cable
It sounds like you haven't selected cable in the "pull-down" menu. You see, you physically have to tell your tv if you're selecting "over-the-air" programs(free), or cable. Select the cable option &
then run "auto-select". Your tv will go through it's steps & find your cable stations. I hope this helps.
Feb 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
