Question about Garmin GPS
Wont power up - Garmin GPS
  • 4 more comments
  • RodBowman May 04, 2008
    1 year old unit went dead today. Tried to reset with power (5 sec) and + key. Tried powering up in bike mount, auto mount, and with AC power adapter - nothing works. Tried USB to PC - not only did it not power up, but the PC didn't recognize that I had plugged anything in. I took the battery out for a minute and reinstalled. Nothing will breath life into this thing. It has worked flawlesslelly in both mounts and on battery until today.
  • T49dpah May 16, 2008
    I have exactly the same problem with my eTrex Venture Cx.
    Reset does not work. The GPS appears dead!
  • tonnelet2 Jul 31, 2008
    I have had this for only 7 months and now it doesn't work AT ALL. I
    thought I could just replace the cord but it sounds as if this is just
    a chronic problem with the unit. I have now read at least 12 reviews
    all mentioning the exact same problem. It will not power up at all. I
    took it to Europe and tried to use it in a car there and it wouldn't
    work. It's a GPS device, right? Isn't it supposed to work in other
    countries? Feel like I made a BAD mistake buying a Garmin.
  • brdwn Aug 19, 2008
    Nuvi 350 worked flawlessly for over a year. I've tried to charge it with wall, car and usb adaptors, nothing works. The unit is completely dead.
  • Over Rover Aug 29, 2008
    Same thing. Tried all reset combos and car/wall/USB cables. Just before it died, I saw the unit going through a power cycle that didn't finish. Dead. Wait until you see that it's $175 to send the unit in. $700 new (18+ months ago), and $175 every two years....plus $75 for the map upgrade? What a deal. I feel like a high-roller! Paper maps are starting to sound pretty good again.
  • ST rider Apr 05, 2009
    Exact same problem as RodBowman. My Zumo 550 crashed during download of mapsource 2009. Called Garmin...Stock answers with no solution. Told to call Raytech and was told it would cost me $280 dollars (CDN) to repair/replace.
    Agree with Over Rover...What a rip off! Paper maps look really attractive now, and a whole lot cheaper to replace.
Did you reset it? lift off the cover plate by slipping your fingernail into the little slot just beneath the Garmin logo. There is a reset button hidden under the cover...
Posted on Apr 24, 2008
My packard acer wont turn , power light comes on when pluged it , but wont power up
Packard Bell, Acer? Which manufacturer? Remove the power, remove the battery, remove hdd and RAM. Plug in the power supply and press On. It will complain that is has not any RAM etc. If it does, insert one RAM chip and try again gradually if not you have a motherboard issue.
Oct 05, 2016 | Acer Computers & Internet
My rci2980wx wont power
the diode is located near power cables and trace from power switch, the diode is quit big and something like IN4001 to 6 Re: Jeff
Dec 01, 2012 | Radio Communications
My automatic windows wont roll down
Click the link below to troubleshoot the problem:--
Power windows not operating?http://whoisbyme.blogspot.in/2012/05/car-window.html
Thanks.
Jun 07, 2012 | Spyder 03-05 Chevy Silverado Vertical...
My cda-9813 wont power on,how to take of faceplate?
sure it will the face eject button should be either on the upper or lower left corner of the face.
Mar 26, 2010 | Alpine CDA-9813 CD Player
Power windows and power locks wont work
Check your fuses first. Then check for power at the switches, and power from the switches to the respective solenoid and motor. Most likely it's fuses. Also check where the wiring runs through the door into the car for bare spots in the wiring that might have blown the fuses.
Jan 21, 2010 | 2004 Mitsubishi Endeavor
Car wont start and there is no power to it at all. The security light is on?
do you know if you have an anti-thieft device in your car. sounds like it may be armed and connected to your battery.
Oct 18, 2009 | 1995 Jeep Grand Cherokee
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Phone wont power on
i have a change my password and many time i type wrong password then my handset not work
its show jvm error 513
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
GPS Logo
194 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
