Question about Denon Audio Players & Recorders
Unlock code for Denon DVD 1103
We purchased our DVD player while living in China 3 years ago, and now on our return to Australia, we are unable to play Australian DVD's.   The local Denon store advised us we would need to send the player to Japan!! I was wondering if anyone could possibly help with an unlock code which would allow us to continue to use this player?
Many thanks and regards, Cathy
SOURCE: The DVD player does not recognize disks that it used to play before.
It sounds like the DVD region (a setting in both your OS and your DVD hardware) may have been changed. DVD regions are the agreed upon method (by entertainment companies, hardware manufacturers and governments) to limit cross-border sharing of media. Most valid (read: non-pirated) DVDs have a region code. Your DVD drive will only play DVDs with a region code that matches the DVD region code set on the DVD drive.
You didn't mention your OS but if you are running Windows XP then go to Start->Control Panel->System->System->Hardward->Device Manager and find your DVD player. Right-click the DVD player and select Properties from the menu and you should see a properties dialog-box with a DVD region tab. This is where you can change the DVD region that your player will recognize. Be careful, don't play around here, most DVD players have an embedded limit on the number of times (4-or-so) the DVD region can be changed.
Hope this helps.
-Ed
Posted on Jan 16, 2008
robotek
  • 1512 Answers
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
jerryg50
  • 1689 Answers
SOURCE: denon udcm m7 cd player often reads ERR on play and eject
Try cleaning the laser first. Take care, because it is delicate.
Some instructions of how to clean a CD laser:
http://www.wikihow.com/Clean-a-CD-Player
If the cleaning does not fix the fault, it is possible that the laser is weak, or there are some problems in the electronics in the CD player. This is not something you will be able to service yourself, unless you are properly trained, have experience, and have the proper setup to perform CD player servicing.
In most cases these CD players are not cost effective to service. You can contact the orignal manufacture for details or any recomendations.
Jerry G.
Posted on Apr 29, 2008
SOURCE: DVD code
I just figured mine out. You need to enter 138931 when you get to the preference menu. It will then show the region. Use the up/down button to select '0'. This will unlock the DVD. Make sure there is no disc in the player, or you cannot access the preference menu. Hope this helps
Posted on Aug 10, 2008
  • 11 Answers
SOURCE: denon seperates
The most likely cause of this problem is the laser is becoming weak. You may be able to get a bit more service out of it by manually cleaning the laser with a cotten bud and some alcohol. However the only real solution is to replace the laser assembly.
It depends on how good at taking things apart and putting them back together you are, weather you should try this yourself. The laser assemblies often have the part number on the side of them, if not you will need to contact Denon who may tell you what it is if you are lucky.
Almost all laser assemblies come fully clibrated and all you need to do is remove the old one and replace it with a new one. You can get the parts from CPC in the UK unfortunately I don't know about other countries.
Regards, Andrew
Posted on Sep 14, 2008
How do you unlock region code on Samsung BD-H6500 smart blue- ray player
The hack for this 3D Blu Ray player is the same as for previous models.
1. Make sure NO disc or usb stick is inserted into the player.
2. Turn on your your blu ray player.
3. When the main menu appears, press the REPEAT button followed by the region code your player is currently locked to - depending on which country
you are in (eg: in Australia press "REPEAT 7 6 8 8 4".
4. In the top right corner you will see your region code flash (eg: 4 for Australia).
5. Press 9.
6. Turn off and on and your BD-E6500 is now region free.
How this differs from the opening post is no need to open and close the disc tray.
So, after pressing REPEAT please enter one of the following codes the matches your current region lock:
1 - 2 9 3 3 4 (US)
2 - 5 7 5 3 8 (Europe)
3 - 5 6 7 3 2 (South East Asia)
4 - 7 6 8 8 4 (Australia / South America)
5 - 5 3 8 1 4 (India, Ukraine, Belarus, Russia, Africa)
6 - 2 4 4 6 2 (China)
9 - Region Free
Then press '9' and your player is region free.
Jan 12, 2016 | Samsung Televison & Video
Unlock region sony sr170
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
Most DVD players allow one change. So if you buy a region 1 player and live in region 3 you can change the region to 3. But if you return to region 1 you can't switch back.
If you have a computer and a toaster to burn your DVD's, there are program m's that can rip a DVD to a folder on your computer and then recode the files to a DVD that has no region.
If you have lots of DVD's it would be wiser to rip the DVD to the PC, remove the region code and put the content on a media player.
In a few years you can't buy DVD's. Perhaps some blue ray DVD with 4K or 8K HD will exist for a while, but ???
Jul 12, 2014 | Televison & Video
How to unlock my dvd for all regioens
You need to ask GOOGLE if it is any modified firmware for you DVD (and of course you will burn you warranty card after reflashing) ;)
Jun 06, 2011 | Philips PD703/37 Player
We purchased a Denon v310 to play multi format dvd's and the message we get is wrong region, how do I unlock?
  1. Turn the unit on
  2. Press the OPEN/CLOSE button
  3. Press CLEAR, 1, 4, 7, 0, CLEAR - "TEST MODE" will appear on the display.
  4. Press UP; "00 XX" (XX is a numerical value) will appear on the display. The first two digits are incremented by one, every time you press UP
  5. Press the UP key until you see "12 XX" (default is 24) on the display
  6. Press 2, 3, ENTER
  7. Press UP key again and you will see "13 XX" (default is 23). If it does not say "23", press 2, 3 on the remote and then the ENTER button
  8. Press the UP key again and you will see "14 XX" (default is 01).
  9. Press 0, 0, ENTER
  10. Press RETURN
  11. Press CLEAR twice
  12. Press RETURN ("END" should appear on the display)
  13. Press OPEN/CLOSE
May 10, 2011 | Denon DN-V310 DVD Player
I have a Panasonic DMP-BD80 BluRay player purchased in Australia. It cannot read BluRay discs purchased in China. Please help me solve the problem/unlock the region code. Thanks & Regards, Glenn
Please follow the steps : To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
Feb 25, 2011 | Panasonic DMP-BD80K Blu-ray/DVD Player
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Feb 28, 2009 | Philips Televison & Video
Multi region code
An option.
 Download DVD fab or another like product which takes off the region code completely using a PC then copy the DVD onto another DVD using the DVD burner,or find someone who can do this for you.
Jan 07, 2009 | Sony DVP-NS36 DVD Player
Unlock region codes
i fund this by dargan and it worked for me "Def" Camino Real 3, Panama:
icon_minipost.gifRegion code hack posted by dargan, August 23 2008:
Same hack for DVD283 worked for DVD-277
<clipped from other post>
Region code hack posted by mhardial, January 25 2008:
DVD Regional Codes
Code Location
**1** USA (incl. territories), Canada
2 Europe (Germany), Japan, South Africa
3 Southeast Asia
4 Latin America, Australia, New Zealand
5 Russia, rest of Asia and Africa
6 China
0, 255, 9 MULTI REGION
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number (0 – 6).
6. Press the “Setup” button to exit.
Mar 07, 2008 | Televison & Video
82 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
