Sound works buthave no pic rca tv model #L32WD14
  • redneckdad Apr 13, 2008
    satellite
    cable from satellite reciever directly to tv, the problem must be in tv cause i get sound from sat. just no pic i have tv in another rm that feeds off same sat reciever and it is working fine
    President:
  • 1,944 Answers
What is your video source?
Posted on Apr 13, 2008
  • Damen Wong
    Damen Wong Apr 13, 2008
    How is it hooked up to the TV?
I have a 52 RCA flat screen that the sound works but the pic doesn't. I can hear a clicking sound and then the power button light starts flashing
This RCA projection tv model have known to have many parts of capacitors components are dying and dead on the tv power supply board.That the board section where the tv power a/c cord plug into it.U have all the tools and can do bsaic soldering work too?Yes,try website like Tvrepairworld.com to buy the capacitors compponents set they put together and replaced all these capacitors parts on the tv power supply board section,will solved this problems.
Jul 06, 2011 | RCA HD52W56 52" Rear Projection HDTV
Rca L32wd14 has no pic or sound green power light just flashs ????????
It may be sensing short circuits in the power supply or in the backlight inverter boards, those are the two places you need to check first. Try disconnecting the connector from the power supply to the backlight inverter board to see if it turn on, you just will not have pictures but you should have sound.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | RCA L32WD14 32 in. LCD Television
Rca tv model L32WD14 continually turns on and off. What is going on?
You may have failing power supply module or failing main board, you need to do some voltage cheking at the outut terminals of the power supply to see if the voltages come and go.
Parts:
http://www.shopjimmy.com/catalogsearch/result/?q=RCA+L32WD14+
http://www.badcaps.net
Jun 12, 2010 | RCA L32WD14 32 in. LCD Television
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
RCA 27 NO PIC / SOUND - Binking green light
I ouldn't find any good news on the web about this,
so i did a bit of research and discovered that it wouldn't cost me much more than the cost of repair if I went to Best Buy and bought a new HD-TV.
Wow ! The prices have really come down !
Now I'm glad that it malfunctioned !
Oct 20, 2009 | RCA F27TF700 27" TV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where can I find a new replacement remote. Do not want a universal remote.
go on ebay and search you tv type and then type in remote almost always have one cheap
Jan 05, 2009 | RCA L32WD14 32 in. LCD Television
RCA tv on and off
howdmwl,
I don't if you are still online but I would like to let you know how to get you tv repaired.
You find a TV service center and tel them to fix it.
If they are not able to reair it, you take your work order and call 1-877-297-8391 and they will exchange your tv
Dec 29, 2008 | RCA L32WD14 32 in. LCD Television
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
F36550 RCA 36 in TV
Hehehe Its all in a matter of taste I like sony and Mitsubishi. You like RCA you get what you pay for. These sets are good for the L401 in the horizontal drive circuit to cause your problem as well as a blown fuse and a shorted horizontal output trasistor and the flyback transformer. if its anything Im thinking off the repair cannot be done by a handi person and should be taken to a pro and will cost in the range of150 to 225.00 for this repair. good Luck
Jul 27, 2006 | RCA F36650 36" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
