Question about Sony HVR-Z1 Mini DV Digital Camcorder
Power turns itself off
Whether it is on battery or mains, the camera turns itself off and on. Ive had the camera 9 months, it worked fine unil 2 days ago (that's when it started doing that, only occasionally at first, but getting worse). Thanks for your help.
My email address is jbayonas@yahoo.com
  • Anonymous Feb 05, 2009
    Hi, My camera also turns itself off and on all by itself. I doubt is it any setting, because I've seen it cycle off then on up to 20 times all by itself with less than 5 seconds apart. What is wierd is that it works fine for about 20 minutes then begins to do that.
    just to prove my point, i even filmed it doing this with another camera so I can show a tech - because the camera will work fine when I show it to one for sure!
    on another note, my camera also is not recognized by my computer. I've tried different cables, computers and nothing, and I think the two issues might be related. I've seen some internet postings about how the camera iLink input board can burn out if not connected properly to the computer. Well, this cycling off and on was happening when I was trying to capture as well.
    Genius:
  • Sony Master
  • 1,673 Answers
Carefuly check for your model if there is an auto power off feature! Many of these devices have this for battery power savings. Some of these models can be set to as little as 1 minute up to several hours.
If there is an actual defect, you will have to send the camera to the manufacture rep for service if it is not a set up in the menu for auto power off. The power supply may be at fault, or some component on one of the boards is changing spec and is causing a safety shutdown.
Most of the repairs in your camera are done by module and board change. There are some factory procedures for performing specific setups that the average service center cannot perform.
Get an estimate before accepting repairs. In many cases with home video equipment that is out of warranty, they are not worth servicing.
Jerry G.
Posted on Apr 13, 2008
My Lumix DMC-LX5 camera won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
My camera, a nikon d70s, wont turn on and work. ive taken the battery out and out it back in, still wont work. i then tried 2 charge the battery but still wont work. i then tried to re-set it but it still...
If the camera does respond when you hold down the shutter release, then the internal clock battery may have drained. As the manual says on page 17, charge your main battery, put it in the camera, and leave it be for up to three days.
Feb 15, 2011 | Nikon D70s Digital Camera
I have a Kodak M1033 camera that I bought just over 6 months ago. I took it on holiday it worked fine and then suddenly it switched off. Since then it only powers up for about 5 seconds, shows a unfoc
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 02, 2009 | Kodak EasyShare M1033 - black Digital...
My samsung tocco will not turn on! the screen turns on, saying SGH-F480, with the bar across the bottom loading up, but when the bar gets to the end, it just goes blank for a sesond, and then repeats this...
this happend to me, i think you can confuse the touch screen, i just took the battery out and put it back in again,and it worked with no memory loss or anything.
Jan 11, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Canon 40D can not turn on
Same problem. Fully charged main battery. In my case, I hadn't used the camera in over 6 months. All I did was pull the main battery and then pulled the small CR 2016 button cell battery located inside the main battery compartment and re-inserted both batteries. The camera made a quiet click and then turned on with the main power switch and asked to reset the date and time. Works fine now. If this doesn't work just purchase a new button cell.
Sep 17, 2008 | Canon EOS 40D Digital Camera
Camera won't turn on with new batteries or power cord
I heard from another posting on here and the answer, that someone took fine sandpaper and cleaned off the terminal ends of both battery and camera and blew out the dust particles from that before replacing the battery, then then camera worked. I have yet to try it with my Kodak camera that is 2 years old and suddenly died too! The batteries are fine and work in other cameras.
May 07, 2008 | Kodak EasyShare C643 Digital Camera
Power does not stay on.
Check out the Samsung Tech Help Team But A stuck lens that is then given some 'help' does not bode well- these are very delicate mechanisms- Chances are it is now damaged - and repairing Digi Cameras is not an economic or technicalfeasability
Jul 02, 2007 | Samsung Digimax L60 Digital Camera
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Sony HVR-Z1 Mini DV Digital Camcorder Logo
228 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
