Question about RCA F38310 38" TV
No Power TV will not power up at all. It is dead. Is this the fuse that was mentioned in one of the replies or is this deeper like a power supply unit? Any idea on the cost to repair this. The TV is 5 years old and we got if for around $500. Trying to figure out if we should call repairman or just search for a new TV?
  • 2 more comments
  • Anonymous Apr 27, 2008
    I found this TV, Today and decided to try to fix it. I found the exact same problem with the 2 caps you described. they were popped up on the top.
    I also tested and they seemed fine but only had a DVM with mo cap tested on it. I pulled them out and am ordering 2 new ones like you suggested
    4700mf 25V, I do not know which diode you are referring to and was wondering if you can give me the location on the power board.of the diode that may also be bad. Thanks for the tips I might be able to finally have a bigger TV.
  • Anonymous Jun 04, 2008
    Mine went dead. I found the standby regulator and a resistor blown. Would something else cause this or should it be ok by just replacing the parts?
    My RCA F38310 went dead and I found the standby regulator and a resistor blown. Would something else cause this or should it be ok if I just replace the parts?
  • samlii Sep 25, 2008
    I also have no power however I seem to have some other problem I think. The Caps look fine, however two resistors blew (R14131 & R14110) does anyone have the values of these and a possible reason for them blowing. Could this also be a case of bad caps (wasn't able to test them, but they weren't visibly stressed)
    Problem Solver:
  • 10 Answers
I am having the same problem. I have done some research and found a notorious cap and diode problem with this set. The two 4700uf caps (C14113 and C14115) on the DM1 power board (the board to the left of the sat. box when you look at the set from the back) are under rated and will eventually fail. When these caps fail they tend to take out diode CR14105. This may be your problem. If it is, you can replace the caps with 4700uf 25V 105c and the same as original diode. In my case the diode appears to be ok. This info comes from some forums and a service buletin from Thomson Co.
Posted on Apr 25, 2008
  • Adam Phillips
    Adam Phillips Apr 28, 2008
    The diode is not a trditional axial diode. It looks more like a transistor and is clipped onto a heatsink. The diode is in the same general area as the two caps. check the numbers on the board and you will find it. Good luck.
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
WE HAD A LIGHTING STORM AND I HAVE NO LIGHTS ON MY BRAVIA WILL NOT TURN ON IS THERE A BREAKER OR FUSE TO LOOK FOR
There is a fuse in the tv power supply board,a fuse it is located near the a/c socket plug in of the tv power supply board.Lighting storm pack a huge anount of power and magnatic static field.If ur tv was in that path.U will not fixed it with a new fuse the tv whole power board probally dead already and those other circuit boards on the tv might be dead too.Good look with the replacement of the fuse,maricles might happen ur tv just have a dead fuse only.Not must take to or call many tvs shops and get the best estamates prices to fixed the tv.Not a do it self project,if tv a got hit by a massive power surges.
Aug 11, 2011 | Sony BRAVIA KDL-46V3000 Television
Tv does not turn on , there was a power outage and since then it wont turn on. there is power to the outlet
If the TV is completely DEAD. Check the main fuse in the power supply. Replace the fuse with exact amperage. Make sure you unplug the TV before taking the cover off. If the power supply keeps blowing the fuse, replace the power supply. Be very careful high voltage can kill!
Best of luck
AAA TV SERVICE
Jun 12, 2011 | LG 42LG30 42 in. LCD HDTV
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
Clicks and red light shows but dosn't have enough power to start up the TV. Is it the fuse?
No,it is not the fuse.The tv LED power light indication on the front of the LCD screen panel flashes?Yes.The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.If u have tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders.Know basic electronic and also can do basic soldering work?U can check the power supply board for those dying and to be dead parts call the capacitors.These capacitors parts alway bulges up on it tops or puffing up on it tops.By replacing these dying and to dead capacitors will be fix the power supply board than,no needed to buy the whole refurbish power supply board for the replacement.
Nov 12, 2010 | LG 42LG50 42 in. LCD HDTV
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 19, 2010 | ViewSonic VA1703wb Monitor
Dead TV
U know basic electronic's,and u know how to do soldering?Have soldering iron,tools and solders?The power supply board,the board that the power a/c power cord plug into it.That the power supply board have these parts call capacitors are dead.These capacitors alway bulges up on it top or puff on it top.Check all around the power supply board and it supporting boards.Replaced these dead leakage bulges up on it top or puff up on it top.Or tries websites like Shopjimmy.com,Ebay.com to buy and replaced the whole refurbish power supply board.
May 28, 2010 | Hitachi 32PD5200 32 in. HD-Ready Plasma...
Tv gets no power http://www.fixya.com/support/p485870-philips_50pf9830a_50_in_hdtv_plasma
Hi my name is Roety,
I can help you with your issue ,
No power means no lights at all, dead set
Call a repairman and expect to spend $275 for a fuse or $550-$600 for a new power supply or SSB board
Check the power supply board for 5 volts , if 5 volts standby is present replace the SSB board.
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Oct 07, 2009 | Philips 50PF9830A 50 in. Plasma HDTV
TV will not turn on
Assuming you are absolutely sure the TV is getting power,
If you have an ohmmeter, measure the resistance between the two prongs on its plug. If no conductivity (over 1 meg Ohm) the fuse inside is popped. Take the cover off, look in the area near the power cord, it is the usual 5AG type (glass cylinder) fuse. If you replace it and it pops again then measure all the diodes in the rectifier circuit (near the fuse).
Many times power transients will just blow these input power devices. However, many times it will go much deeper and get the TV's processor brain. If the TV is anywhere near 10 years old, I wouldn't go any deeper than the input power circuit.
Jan 18, 2008 | Televison & Video
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
RCA F38310 38" TV Logo
267 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
