Question about LG DLG5932W Gas Dryer
Dryer runs like everything works but it is not heating
I need to know where the heating element is and what it looks like and how do I know if that is the problem?
Thanks
  • Anonymous Nov 07, 2008
    but where is the combustion chamber tube?? I have the same problem.
  • 489 Answers
Check the high limit switch located at the combustion chamber tube.  There is reset button.  Push the button.  If you hear a click, then it should work.
Posted on Apr 28, 2008
Ehow com
first check the fuse that powers the heating elements, and then check the resistance of the heating elements must be between 75 to 1200 ohms. I hope that the fans are operating
Jul 16, 2014 | GE 7 Cu. Ft. Stackable Electric Dryer...
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 86870800 Will not heat...
The reason to this problem is due to the faulty heating element.
Once the dryer runs with no heat then there is a problem in the
heating element which cannot be repaired,so you need to
replace it.
Sep 01, 2009 | Kenmore 63942 Dryer
No heat but dryer works normal otherwise...
motor only needs one breaker to work element needs both they may look on but flip them off hard then on 3 times.... I know you say the motor is running... JUST DO IT IT if no heat then check element
Aug 12, 2009 | Dryers
Everything seems to work, but can not get heating element to work
The first thing to check is for a burned thermal fuse. It is about one inch long and is located inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown fuse and it will need to be replaced. Hope this helped and best wishes.
Aug 03, 2009 | Dryers
Dryer run won't heat up took off back panel don't know which tube contain element. if that not the problem don't know where to locate thermal fuse i need pictures diagram illustration
Hi, if this is an electric dryer and is a whirlpool model, the element is located in a housing on the right side (looking at the back)
You can run the dryer and check with voltage meter to see if it is getting 240V. If there is voltage, replace the element. If there is not voltage, check the thermostats and the fuse for continuity. If they do not have continuity, replace them.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer runs as usual but won't heat up.
you need to check continuity across the heating element with an ohm meter looks can be deceiving
Apr 14, 2009 | Dryers
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
LG DLG5932W Gas Dryer Logo
165 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
