Question about IBM ThinkPad R50e Notebook
Volume Display The green volume and mute display is suddenly gone. How can I get it back?
None of the solutions in the forums work, at least they didn't work for me. I finally got the solution from Lenovo support. You need the hotkey driver from their website. Download it here:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-38953
Follow the instructions on the above site to run hotkey\setup.exe and reboot, and you will have your on-screen displays back!
Posted on Mar 28, 2009
    Scholar:
  • 125 Answers
I assume you mean the green bars across the screen? It may be a setting in the control panel, or ibm utility to show on screen or not. Or, you might have to download the utility from ibm's support website and re-install it.
Posted on Apr 23, 2008
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Suddenly the beep volume is almost mute- how to bring the volume back up?
You will most lokely need to replace the "beeper" as its components have become worn ut with time
Oct 03, 2014 | Sanyo Microwave Ovens
Como habilitar mute
queria tmb
You may also use the following shortcut:
Dial ''1'' to exit programming mode and store the option as Enabled
(Mute Button, Record Out, Record Warning Tones), or
1-Line (Display) or the Per Plug setting (Headset Volume).
Dial ''2'' to exit programming mode and store the option as either
Disabled (Mute Button, Record Out, Record Warning Tones, or
Headset Volume) or 2-Line (Display).
Dial ''3'' to set the Headset Volume to the Per Call setting. (This
option is ONLY available for the Headset Volume setting.)
1-While on-hook (the headset must be unplugged), press 'SELECT'
+ The Light next To 'SELECT' Goes on.
2-PRESS 'MUTE'
+ THE CALLMASTER is in option Programming mode.
3Dial The 2-Digit Code, "68" ("MU").
+ The current Setting (Enabled or Disabled) is Shown on The display.
4-Dial * To chande the Setting.
5 when the setting you prefer is shown on the display, press # to save it an exit Programming mode.
DISPLAYING THE OPTIONS -------
To display the option settings:
1 While on-hook (the headset must be unplugged), press 'SELECT'
Select .
d The light next to
'Select' goes on.
2 Press
''Mute'' .
d The CALLMASTER is in option programming mode.
3 Dial the 2-digit code, ''00.''
d The display shows the option settings (three options are available
on the CALLMASTER III; four options are available on the
CALLMASTER II).
d The display will return to normal after approximately five seconds.
NOTE: Use the same procedure for international settings. However, you
must dial ''11'' instead of ''00.'' The top line of the display shows the
international settings, and the bottom line will either be blank or report a
problem with the (EEPROM) memory used to store the options an
Voc? tamb?m pode usar o atalho seguinte:
Dial '' 1 '' para sair do modo de programa??o e armazenar a op??o como Ativado
(Bot?o de mudo, Record Out, Record Aviso Tones), ou
1-Line (Display) ou a defini??o Per Plug (Headset Volume).
Dial '' 2 '' para sair do modo de programa??o e armazenar a op??o como quer
Disabled (Bot?o Mute, Record Out, Tons de aviso Record, ou
Volume fone de ouvido) ou 2-Line (Display).
Dial '' 3 '' para definir o volume do auricular para a defini??o por chamada. (Este
op??o s? est? dispon?vel para a configura??o de volume do auricular.)
1-o monofone no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
+ A luz ao lado ' SELECIONE ' continua.
2-PRESS ' MUTE '
+ O CALLMASTER est? no modo de programa??o op??o.
3-discar o c?digo de dois d?gitos, "68" ("MU").
+ A configura??o atual (ativado ou desativado) ? mostrado no display.
4-Dial * Para Chande o Ambiente.
5 quando a configura??o de sua prefer?ncia ? exibido no visor, pressione # para salv?-lo de um modo de sair da programa??o.
Apresentar as op??es -------
Para exibir as configura??es de op??o:
1 Enquanto estiver no gancho (o fone de ouvido deve ser desligado), prima ' SELECIONE '
Selecione.
d A luz ao lado
' Select ' continua.
2 Pressione
'' '' Mute.
d O CALLMASTER est? no modo de programa??o op??o.
3 Disque o c?digo de dois d?gitos, ''00.' '
d O visor mostra as defini??es de op??es (tr?s op??es est?o dispon?veis
na CALLMASTER III; quatro op??es est?o dispon?veis na
CALLMASTER II).
d O display voltar? ao normal ap?s cerca de cinco segundos.
NOTA: Use o mesmo procedimento para as configura??es internacionais. No entanto, voc?
deve discar '' 11 '' em vez de ''00.' 'A linha superior do display mostra a
configura??es internacionais e a linha de fundo ou ser? em branco ou relatar um
problema com a mem?ria (EEPROM) utilizado para armazenar uma das op??es
Oct 29, 2013 | Avaya 6408D+ 8 Button Display Telephone
I cannot control the volume on my str-de598. The display shows it changing up/down. Pressing mute shows mute on the display but the volume is not muted...
open the remote c. and clean the keypads form dirty, corrosion, oxide, use contacts cleaner and fix it.
God bless you
Jul 31, 2013 | Sony Televison & Video
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Jan 22, 2013 | Sony KV-27V55 27" TV
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
All of a sudden our receiver stopped working. The display looks fine, but there is no sound.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
If you have an aha moment turn the volume to something reasonable and see if that helped.
Jun 26, 2011 | Harman Kardon AVR 320 Receiver
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Friend turned volume up.. now display/volume died no sound
Sounds like your friend burned out the power amplifier. That would be the only reason none of the channels work. Unless the unit was muted by accident and no one checked the mute function - though I doubt that.
Jul 04, 2009 | Denon Audio Players & Recorders
IBM ThinkPad R50e Notebook Logo
966 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
