Question about Powerware 9120 UPS System
9120 Capacitor & transistor problems
Hi
1. Where do I find the 100uf/63v and 2200uf/16v capacitors.
2. I also have another 9120 which is not powering on. I opened it and found a blown transistor N507AD G30N60C3D. Do you have it instock or tell me where I can order it from.
Regards
Curtis
St Kitts
West Indies
    Scholar:
  • 168 Answers
Well all of the above mentioned parts are available in any electronics spare parts store. The capacitors are common which you can easily buy in any electronic store. Good luck!!
Posted on Apr 22, 2008
I can hear it but not see it
If you are getting the following kind of breakdown:
The TV do not starts (the LED flashes) and / or slow start then you can refer the following solutions
Replace capacitor C2937 / a 10µF 100µF
Add a 63v capacitor of 1uF / 16V / position 2936.
Change resistance R3955 / 220K with a 4.7 K
Those capacitor and resistor are in the power stage on the printed circuit board
I hope this may solve your problem but for you must have some technical knowledge about it.
May 12, 2011 | LG Televison & Video
I have the velodyne DLS4000R and it keeps popping at high volumes ??
Popping ????? if popping sounds mechanical: chek for speaker blowned (replace or repair speaker)
if popping sounds electronic: chek circuitry.
Apr 03, 2011 | Velodyne DLS4000R Subwoofer Speaker
No picture
Dec 02, 2010 | Philips Televison & Video
Tv won't stay on
HI, thank you for visiti fix ya.
your solution is here. ( replace capacitor in power supply, 2200uf 16V, 220uf 16V ,33ouf 25V 100uf 16V), you will se capacitor vented or bowed.
Look the picture for best result.
If do you have question inthe future, I will be here.
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch power light comes on no pic.,shuts off makes noise
I think you have a shorted hori output Transistor NTE2324 if it makes a low squealing sound also ck capacitor 114,120,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and other 2 are 220uf 35v.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
3-5 error code on mitsu wd-52725(chassis fan failure)
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Feb 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
3 green blinks
Look on Deflection board cp 150 2200uf 16v capacitor and there is 2 more capacitors 220uf 35v replace both of them. Green and Gold writing on caps.
Sep 09, 2008 | RCA D52W19 52" Rear Projection Television
Power supply problem
My tv did the same thing. Replace the capacitor marked C926 that is marked on the main(big) board. It fixed mine. The lead was broke off inside the capacitor.
Jul 12, 2008 | JVC AV-35750 35" TV
Help - I have the same Fault!
Normally DC BUS FAULT is fixed by replacing C14 and C10. C14 is the 100uf/63V and C10 is 2200uf/16V. They are located between the heat dissipator and the logic board near transformer TX1.
Mar 12, 2008 | Powerware 9120 UPS System
Powerware 9120 DC Bus Fault Problem.
there is a 100uf/63v capacitor near the IRF630 fet. You need to replace this in order to fix this error. Along there is also a 2200uf/16v capacitor. It is a good idea to change the both at the same time.
Feb 13, 2007 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
235 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
