Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
Sony Television
By bevbidwell on Apr 13, 2008
Did you ever find a solution to your tv clicking and not coming on but the stand by light flashing? I'm having the same problem and can't seem to find a solution. I push the power button it clicks 5 or 6 times and then it goes off and the stand by light flashes 4 times.
Can you help me? Thanks.
Our Sony suddenly made a sound like we had shut it off, went black and the standby light started blinking. We tried shutting the power off for a while, when we turned it back on all we had was the standby light blinking constantly. Next we unplugged it for the night hoping to reset something, when we plugged it back in nothing had changed. No pattern to the blinking, it is constant.
Solution #1
posted on Apr 13, 2008
Somewhat Helpful)
jerryg50
Rank: Wiz
Rating: 84%, 889 votes
In these sets, it is common that the flyback transformer assembly, and sometimes the horizontal output transistor. With this there may be some failed capacitors in the horizontal section. When this type of failure occures it is possible that the power supply has some parts that also must be changed. The exact parts will be determined by the way the failure occured.
In some cases the CRT also goes shorted inside of the electron-gun. In this case the CRT must also be replaced.
In short order, you should take the set in for an estimate. It may be on the expensive side to service. If you are lucky, only the flyback may need replacement or some other simple part that is putting the set in to the protect mode.
Jerry G.
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
how to set the caption version display
Answer
The CT- 36HX42 TV will not turn on via the remote or the manual button. I have new baterys in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
