I changed the filter on my ruud 1x2000 the other day did not try to turn on until yesterday.tried ac nothing then tried heat nothing. changed termastat still nothing.
    Genius:
  • 1,554 Answers
Is this a whole house air conditioner ,
if so check the fuse panel,
check to see if the outside unit runs at all , compressor or fan.
check the ac transformer power to the thermostat
check the switch in the ac closet
doe the internal fan run if you switch to fan only.
Posted on Apr 13, 2008
How do I get my AC running again? Ruud UBHC AC unit isn't running. Started yesterday or today.
Sounds like there is no control voltage. Either the transformer to reduce the voltage from 110 volts to 24 volts is not producing the 24 volts needed for control voltage, or most furnaces have a small 3 or 5 amp fuse mounted on the main control circuit board that may be blown. Other "outside circumstances" may involve a break in the thermostat wire...more than likely the red wire if you are getting nothing to work. I have seen evidence of "critters" that have chewed through the low voltage thermostat wiring that would keep the thermostat from controlling anything. To check this, go to the furnace and jumper the red & green wire to get the fan running just to isolate if it is a thermostat wiring severred. Good Luck.
Dec 11, 2014 | Ruud UBHC Air Conditioner
"I have a 13 year old 10 SEER Achiever RUUD UPKA-049JAZ heat pump when you turn the AC on the ouside unit makes surging sound about every 3 min after about 45 min the ac will kick on."
sounds like compressor is going bad .. first try a hard start kit.. have staved off replacing compressor many times.. may last a long time may last 1 day
also check charge
May 20, 2014 | Ruud Heating & Cooling
My Ruud AC unit compresssor is creating a lot of condensation and home is not properly cooling.
check ur coils are they dirty how is your filter on hot days it will condensate alot however a unit is desighned to opperate for an average of around 87 degree day and may need the superheat adjusted. check and make sure the bigger line coming off that unit is very cold hold your hand over the outdoor fan is the heat off it very warm
Sep 11, 2010 | Ruud Central System Air Conditioner
The blower in my Ruud gas furnace won't shut off. It just runs and runs. The thermostat is set to "off" and the fan switch is set to "auto". We haven't used the furnace or AC the past few months since we...
I'm not sure what setup your unit has but the fan relay sound like it is bad. If your blower connects to a circuit board then the board could be bad. Different units use different ways to control the fan. Some use a relay like I mentioned. Some use the circuit board (newer units). Some even use a sequencer. The first step will be finding what yours is using. Since you tried disconnecting the green wire from G already and it didn't cut off I would think your thermostat is not the problem. Let me know what you find.
Aug 15, 2010 | Ruud UAKA037 Air Conditioner
My ac stopped putting out cool air on a hot day. I turned off the ac and replaced 2 dirty filters and waited 4 hours to turn back on but the air does not seem cool. Did I not wait long enough time for it...
check to see if the fan is working at the condensing unit. if it is, check that the fan is pulling heat off the unit as it should. make sure the cage is clean. no restrictions as far as air flow. clean . check duct work for leaks. inside, if you replaced the filter/s. the evaporator is dirty. call a prof,
Apr 25, 2009 | Ruud UBHC Air Conditioner
Replacement of filter on Ruud Achiever series heat pump/AC
You must first remove the blower compartment panel. The filter should be in there. However, since this unit is in a crawl space you may have a return air filter grill. Look at your return grill. Does it have a filter? If not does it have latches so that you can open it? If so measure the opening and install a new filter there. I hope this helps. Please don't forget to give me a Fixya rating.
Feb 21, 2009 | Ruud UBHC Air Conditioner
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
