Need driver for Acer moniter X191W on windows NT 4.0 Server the cd has an ealire version of NT drive but not 4.0 Server.
  • cdpd31 Apr 30, 2008
    Could not get there from here Gateway time out error on upstream server
    Sergeant:
  • 221 Answers
Here is a link to a driver for windows vista. The Acer website did not have drivers for other operating system. Try it and see if it works
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=544227&CFTOKEN=92875617
Posted on Apr 13, 2008
Sss i forgot my email and password
Don't know about your email but if its a Windows password you have lost go here http://pogostick.net/~pnh/ntpasswd/ and download the "Windows Change Password / Registry Editor / Boot CD" from the link Password reset CD/USB bootdisk: Instructions & image to download.
NOTES
"The password reset and registry edit has now been tested with the following:
NT 3.51, NT 4, Windows 2000, Windows XP, Windows 2003 Server,
Vista, Windows 7 and Server 2008.
As far as I know, it will work with all Service Packs (SP) and
all editions (Professional, Server, Home etc)
Also, 64 bit windows version (XP, 2003, Vista, 2008, Win7) shold be OK.
To make a bootable USB drive / key:
1. Copy all files from this CD onto the USB drive.
It cannot be in a subdirectory on the drive.
You do not need delete files already on the drive.
2. Install the bootloader (you may have to be administrator)
On the USB drive, there should now be a file "syslinux.exe".
Run this from a command line, like this:
j:syslinux.exe -ma j:
replace j with some other letter if your USB drive is on another
drive letter than j:
On some drives, you may have to omit the -ma option if you
get an error.
If it says nothing, it probably did install the bootloader.
Please note that you may have to adjust settings in your computers BIOS
setup to boot from USB.
Also, some BIOS (often older machines) simply won't boot from USB anyway.
Unfortunately, there are extremely many different versions of BIOS,
and a lot of them are rather buggy when it comes to booting off different
media, so I am unable to help you."
Feb 01, 2014 | HP Compaq Presario V2000 Notebook
Tip
Windows Password Key 8.0 is considered as the best tool to reset local...
You can change a Windows User Account password that is on any Windows computer from any other Windows computer regardless of whether the User Account is on a workstation, a stand-alone server, or a Windows domain controller. Additionally, it makes no difference whether the password being changed from a workstation, a stand-alone server, or a Windows domain controller. This is true for any NT 4.0, W2K, XP Pro and Windows Server 2003 computer.
To change a user's password at the command prompt, log on as an administrator and type:
net user danielp * /domain
(This is only an example, use your own username)
When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user danielp 123456 /domain
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Note: If you type these commands on a member server or workstation and you don't add the /domain switch, the command will be performed on the local SAM and NOT on the DC SAM.
on Apr 28, 2010 | Microsoft Windows XP Professional SP2
How do i install windows 2003 standard, to my new Acer AT110 F2? on Acer smart cd there's no option for 2003 server :(
I just checked the specs and it supports Windows Server 2003 so it must be possible. They probably did not make a setup wizard for it so you will have to do it the "old fashioned" way. Load the Windows Server 2003 disk in the CD/DVD drive and boot to it as you would any Windows install. If it reaches the screen where it displays the hard disk(s) you are good to go. While the installation is running go to Acer's website on another computer and download the 2003 drivers to a USB drive. When the installation completes, install the 2003 drivers and you are ready to customize it to your needs.
If it doesn't find the hard disks, you probably purchased the optional PCIe 4-port SAS RAID card and Windows 2003 doesn't have a built-in driver for it. You will need to press F6 after Windows install starts so it will prompt you later for a driver for your disk controller. This will allow you to manually install the driver which you should be able to find on Acer's website. (F6 Info: http://en.wikipedia.org/wiki/F6_disk)
I hope this helps!
Nov 30, 2012 | Acer At110 F2-E3-1220 E3 1220 1P
Need driver for Acer x191w moniter
http://www.nodevice.com/driver/X191W/get72415.html
get the monitor driver from this link.
You just have to put the code in the bottom of the website in above link and download it.
best of luck!
Mar 12, 2012 | Acer Computers & Internet
I send a document to print but it does not print, howver if a request it to scan it does it what do I need to do? in one occassion it told me that it was not set to work in a USB port but indeed it is my...
Hi melocoton777,
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software, then unplug the usb cable. 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press. NOTE: IF YOU HAVE OTHER PRINTER INSTALLED ON THE COMPUTER DON'T RENAME THE W32X86 FOLDER. JUST PROCEED WITH RESTARTING WITH THE COMPUTER;
The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
just send me an update if the issue would be same.
Oct 18, 2009 | Dell 922 All-In-One InkJet Printer
Printer can't communicate with computer
Hi rcamp3,
you can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
From the start search box type spool and press .
LexBce Server
Print Spooler
Oct 05, 2009 | Dell 924 All-in-One InkJet Printer
Acer Aspire 4720Z drivers for windows 2000/2003
Hi there.
As far as i know XP drivers will work on the old NT system, if you have tried and have had no luck please post back.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5610-4720 Notebook
Cd/dvd driver
Hi
cd/dvd drive doesn't require drivers at all, the drivers come with windows and if you are missing or corrupt drivers on the cd / dvd drive then
try this:
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
if that doesn't solve the problem then use the windows cd to install windows to the computer again and start over or use the restore cds to restore the computer.
Apr 11, 2009 | Acer Aspire 4720 Notebook
Is it possible to upgrade NT4.0 to Windows 2000 or XP?
Hi zhonglee upgrading from Win NT 4.0 to Win 2000 or XP on your server for personal use or single use is fine and definitely possible but mind you W2K Pro or XP will not provide services of Server OS like Win NT 4.0 Server
Jun 17, 2008 | Acer Altos 600 Server
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
