Question about Siemens 24 in. SE64A630GB Built-In Dishwasher
My siemens built in dishwasher is making all the right noises but not taking in any water.
I believe there is a pump that has a filter that could be blocked but don't have the manual as it was given to me.
Please help!!
  • DOOBERT Apr 13, 2008
    We have been using the dishwasher for about a year now without any problems.
    It is used daily and when switched on yesterday it was making the right noise but sounded dry...
    I opened it and there was no water inside.
    Problem Solver:
  • 4 Answers
I know sounds stupid, but I must ask: Are the water supply valves turned on? Is the water supply pressure good?
A pump usually isn't found on the inlet side. Most such appliances have sediment screens located in the water inlet connections. These will sometimes get blocked with sediment such as lime, for example. Otherwise, you may have a defective controller or defective solenoid. Most units have two solenoids (hot & cold). The solenoids are located at the water inlet hookup (the screen is usually a part of the solenoid). When the washer is started, a metallic click should be heard from the solenoids. Beyond checking the screens and water valves, a repairman should be called in, unless you're skilled with a voltmeter, electrical troubleshooting, and appliance disassembly.
BTW- is this a new installation or has the unit been in service for awhile?
Good luck.
Posted on Apr 13, 2008
  • hitori Apr 13, 2008
    I was hoping that your reply might offer an alternate possibility. But, Debi, my original thoughts on your problem continue to be my recommendation.
    Again, I do wish you much luck with this problem.
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left can remove plastic hose on the left to drain the dishwasher sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
Our Siemens dishwasher retains water and smells
I would check the bottom of the dishwasher to see if there are any bones, old food built up as some of these collection systems have a small disposer built into them.
If you find any food, it's probably that.
Also, you can make sure that the drain line is the proper length and high enough as this is a common problem. Do a good search on proper drain height for dishwasher.
You may run an empty load of dishes with a cup of bleach added to eliminate the odor as well. Bleach will kill any bacteria causing the smell. More than likely the drain hose wasn't installed correctly.
Sep 10, 2009 | Siemens 24 in. SE64A630GB Built-In...
Siemens dishwasher stored for 6 months.Not working.
might be water valves stuck try giving entry pipes a tap. no too hard though
Jan 15, 2009 | Siemens 24 in. SE25T250 Free-Standing...
Siemens Model SL84-A - Water will not pump into dishwasher
heres a screen on the inlet to the water solinoid that plugs up with calcium alot of the time. shut off the water and take the bottom panel off the unit and you will see where the solinoid is. take off the water and then take the solinoid out and apart to clean. reassemble and you will be good to go.
Jan 11, 2009 | Siemens 24 in. SL84A305UC Built-in...
How do i change the waste pipe on a Siemens SE25235 GB dishwashe?
yes. the side panel needs removing to get access to the fill/water matrix. to do this, you need to remove 2 torx 15 sized screws underneath the white seal of the side panel. make sure you have unplugged the dishwasher and disconnected its water supply. once you have access to the water matrix, place a towel or similar absorbant material underneath where all the pipes connect to the matrix (near the back) to prevent any spillages. the waste pipe is the same colour and texture right up to the connection on the matrix and is (i believe) the furthest from the door of the dishwasher. disconnecting the hose shouldn't be too difficult.
Jan 06, 2009 | Siemens 24 in. SE25A266 ExtraKlasse...
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Aug 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Siemens 24 in. SE64A630GB Built-In Dishwasher Logo
860 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
