Question about Apple iPhone Smartphone
ANSWER AND ADDITIONAL INFO
OK.IT'S VERY KIND OF YOU.IPHONE WORKING FEW DAYS EXCELENT BUT I THINK THATS PROBLEM CAUSE ZIBRI TOOL 2.5 AFTER I TRY REINSTALING 1.1.4 FIRMWARE AND UNLOCKING WITH ZTOOL 2.5.I ACCIDENTALY PRESS JAILBRAKE 2 TIMES AND AFTER THAT PROBLEM IS CONSTANT.EVRYTHING ELSE ON MY PHONE IS OK AND WORKONG PERFECTLY.
ONLY THING "SLIDE TO ANSWER" OR "SLIDE TO UNLOCK" DOESN'T WORK.WHEN I RECEIVE CALL I MUST PRESS "TURNOFF" BUTTON TWICE.AFTER THAT I CAN USE ALL FUNCTION BUT INCOMING ANSWER IS DECLINED SO I MUST CALLBACK.
  • Apple Master
  • 19,396 Answers
The slide problem must be firmware as well, if it was the slide sensor the phone would not react to sliding at all. Did you try reinstalling 1.1.4, or a previous version once again with zibri, in theory this should fix it.
Posted on Apr 13, 2008
How to unlock an icloud locked ipad 2
The answer was already here:
Unlock iCloud iPhone 6S, iPhone 5S, iPhone 7, iPhone 6S+, iPhone plus
Download from:
http://unlock-icloud.com
Unlock and remove iCloud for:
All iOS
iPhone 7
iPhone 5S
iPhone 6
iPhone 6 plus
iPhone 6S
iPhone 6S plus
All iPad's and new models
Remove iCloud activation lock, bypass iCloud lock
Real and working by software, work on all Apple iPhones
Trusted solution work 100% i recommand it's verified!
The software is easy to use and the support team from unlock-icloud.com offer good technical support with team viewer and video for unlock icloud and iphone repair solutions. The signal work excelent after i have used this software. The software is clean no viruses or other bad things like other software from internet.
With this software i managed to repair my iPhone 6 iCloud errors and bypass activation lock. It's a realy gsm repair tool.
Feb 21, 2015 | Apple iPad 2
AUTOLOCK PROBLEM
Check auto lock settings and disable it
Apr 13, 2008 | Apple iPhone Smartphone
Tip
How to recover Excel 2007 password
Microsoft Office software developers have been paying more and more attention to the means of protecting users' information, and Microsoft Excel has not been overlooked. Recent versions of the program provide users with advanced features for protecting Microsoft Excel documents against unauthorized access of the information stored in them. The methods include completely blocking access to a document, forbidding saving changes to it. Besides, some expert team even designed Excel password recovery tool to recover Excel 2007 password for those who have lost Excel password.
Set a password to open or modify Excel 2007 password
Set a password to open Excel 2007
  • 1. Click the Microsoft Office Button 3dac3a8.gif, point to Prepare, and then click Encrypt Document
  • 2. In the Password box, type a password, and then click OK.
  • You can type up to 255 characters. By default, this feature uses AES 128-bit advanced encryption. Encryption is a standard method used to help make your file more secure.
  • 3. In the Reenter password box, type the password again, and then click OK.
  • 4. To save the password, save the file.
Set a password to modify a Excel 2007 Spreadsheet
  • In addition to setting a password to open an Excel spreadsheet, you can set a password to allow others to modify the spreadsheet.
  • 1. Click the Microsoft Office Button office.gif , click Save As, and on the bottom of the Save As dialog, click Tools.
  • 2. On the Tools menu, click General Options. The General Options dialog opens.
  • 3. Under File sharing, in the Password to modify box, type a password.
  • 4. In the Confirm Password dialog, re-type the password. Click OK.
  • 5. Click Save.
Remove password protection from an Excel spreadsheet
  • 1. Use the password to open the spreadsheet. (Note: If you don't know the open password, you have to recover Excel password with the third Excel password recovery tool)
  • 2. Click the Microsoft Office Button 3dac3a8.gif , point to Prepare, and then click Encrypt Document.
  • 3. In the Encrypt Document dialog box, in the Password box, delete the encrypted password, and then click OK.
  • 4. Save the spreadsheet.
Recover Excel 2007 password with Excel Password Unlocker Excel Password Unlocker is a popular Excel password recovery tool that can recover Excel password from Excel 97 to Excel 2007
on Jun 09, 2010 | Audio Players & Recorders
How do I input my contacts and calendar info from
Hey, what you need is just an excellent data transfer tool. Here I would like to recommend Jihosoft Phone Transfer. It is a Safe Quick Phone to Phone Transfer for Android iOS, which can help you transfer your data, including contacts, text messages, calendar, photos, videos, music and more from Android to iPhone in a few mouse clicks.
To learn how to transfer contacts and calendar from Android to iPhone step by step, please visit:
Sep 02, 2014 | Cell Phones
My 92 excel stops on hot days. it is hard to restart & when it does only gets a short distance then stops again. Runs fine on cool days All instruments work ok. Can hear fuel pump working.
can you do a compression test on the cylinders! engines that are hard to start/cut out when hot would indicate low compression.
could be head gasket on it's way out!
Nov 01, 2009 | 1999 Hyundai Accent
Work day
Hi Chinnu,
For this you will have to install an Add-in called Analysis Tool Pack.
Kindly follow the below instructions:
1. Open Excel Options (Menu-Excel Options)
2. Click on Add-Ins on the side pane of the Excel Options Window
3. Check to see if Analysis ToolPak is in Inactive application add-in list.
4. If is not, proceed to Step 7
5. If it is in the inactive application add in list, Select Excel Add-ins against Manage and click on "Go"
6. In the add-ins menu check Analysis ToolPak and Analysis ToolPak VBA and click OK
7. Use this formula to find the number of work days excluding Saturday & Sunday in a month
=NETWORKDAYS(start_date,end_date, [Holidays])
In your case give the start date as 1st July and end date as 10th July and Holidays as 0 or 1 (doesn't matter). The answer it will return will be 8 days.
Trust the above helped.
Jul 23, 2008 | Microsoft Office Professional 2007 Full...
Really Dead iPhone
no its sounds like a hardware fault .
not a software fault
when a psu on a desktop goes is it ms fault or hardware vendors fault.
send it to apple you should have warranty for the hardware
Jun 26, 2008 | Apple iPhone Smartphone
ANSWER
Write also the problem to George, if you are not the first one having the problem they may also help. I will be offline in the next hours.
Post any message in one of the existing threads, this same one for example, ( http://www.fixya.com/support/t510299-answer )
otherwise I get in troubles with too many ask me postings from same problem here. I will answer within 24hrs, hopefully sooner than that.
Regards
Iphone camera
my iphone says that storage is not ready everytime I try to take pictures..darnnnnn...
Mar 01, 2008 | Apple iPhone Smartphone
Forgot password
Try this link http://www.download.com/Free-Word-Excel-Password-Wizard/3000-2092_4-10249516.html?tag=lst-0-1 It should help you unlock the Excel file and break the password. Good luck
Sep 02, 2007 | Microsoft Office Standard for PC
Apple iPhone Smartphone Logo
79 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
