Fault cod f011 - Washing Machines
  • DWLincoln Apr 13, 2008
    no point the user manual does not give the error code or what it means, however being an engineer my self i worked it out to be the pump for the wast water took it a part cleaned it set the washer going it work OK now.
    so error code F011 is the water pump failing, try cleaning it befor you call the nice expensive engineer it takes about an hour to clean but swich the mains electric of as you are close to the wires.
    Problem Solver:
  • 14 Answers
Consult owners manuel
Posted on Apr 13, 2008
How to fix cod p20f4 audi Q7 2010 TDI ?
You need to clarify the fault code, as the 'f' is not valid.
Removing the 'f' gives 10 possible fault codes (0-9) ranging from manifold flap issues to the Evaporator circuit (relevant for diesels?) to the exhaust DPF needing a regeneration...
Aug 17, 2017 | Audi Cars & Trucks
Vauxhall fault codes
in my car Vauxhall zafira this cod comes up which is u2100c and can u please tell me how to fix the problem , I change the car key battery . still the light is there.
Nov 29, 2013 | 2006 Opel Zafira 1.9
What is message f011
F-11 means drain pump cannot be activated
make sure wires to pump connected properly
check the pump itself with a meter, (165omhs aprox)
Check the connection on the main power board J9 i think
if all the above is ok you need a main pcb......hotpoint service engineer is the best way to go.
hope this helps.
May 23, 2012 | Hotpoint Aquarius WD640 Front Load...
Cod. fault p0172. type 203t mercedes
this means that it has detected a rich condition. You can get this with a dirty maf sensor suually caused by paper filters, a vacuum in a hose or connection or a fuel pressure problem.
Dirty mafs are easily cleaned even at home with maf spray cleaner. As long as you are careful not to physically touch the actual'sensor you can't hurrt it if it is still good.
May 01, 2012 | 2003 Mercedes-Benz C-Class
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 | Dishwashers
Hotpoint wt761 is showing error codes f05 and f011 can you help
Hotpoint (Indesit) 'f05' decodes as 'pressure switch stuck on full' and 'f011' as 'pump/draining error' which leads me to gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 25, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a P1352 fault on my chevy malibu I replaced icm and coil still have same fault
Was the code P1352 (ERASED) after the repairs were made? After all repairs are made for any (DTC) the code must be must be erased from the cars computer (ECM),other wise the cod will keep comming up as a stored trouble code.I hope you find this helpfull.Good luck.
Dec 09, 2010 | 2001 Chevrolet Malibu
hi i need help i have vw passat 1.9 tdi 66 kw 99 year i have problem the car dont have power to go . turbo its on bot car dont have speed and i have fault 463A and fault 04D5 can same 1 help me pls
Jul 18, 2010 | 2003 Volkswagen Passat
P0400 Exhaust Gas Recirculation Flow Malfunction
Post more information on your vehicle, and the symptons which lead to the fault.
Strictly Saab
Melbourne, FL
Aug 30, 2008 | 2000 Saab 9-3 Viggen
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
