Water does not shut down
When I start the wash cycle, it starts filling with water BUT does not stop. Can you help please?
    Problem Solver:
  • 14 Answers
There is a little cut off device inside the washer it is most likely clogged or might need to be replaced.
Posted on Apr 13, 2008
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
The washer keeps filling and won't stop. Sometimes can get it to stop on the wash cycle but won't stop filling at all on the rinse cycle. Any solutions?
I get this question a lot. Washer is flooding the house, water everywhere, won't stop. The first thing I say is unplug the washer. If the water is still coming in,(which it will on a stuck valve) shut off the water faucets. If that is not possible shut the water meter off. If you can stop the washer with the timer then I would say instead of a bad valve you have a plugged water level pressure hose. Look at this diagram: water%20level%20operation.jpg As you can see the rubber tube from the bottom of the tub allows air pressure to push against the switch till it shuts down the valve and starts the wash cycle. Remedy this problem: Simply remove the tube from the switch and blow it out. Use them lungs!. Get that sand and trash out of the sump. Reconnect the hose tightly and pump out any standing water. Then restart the machine. If you have a good tight connection the machine should start working like normal. No parts needed! LOL!
Sep 12, 2009 | Maytag Performa PAV2200
Water will not shut off
If the washer fills and don't start the wash cycle...
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
Sep 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Washer fills with water, spins but does not aggetate
LG washing machine, the water continue, not stop
Mar 15, 2009 | Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
COLD WATER DOESNT SHUT OFF AND SPIN CYCLE STARTS AND STOPS
The pressure tube switch tubing gets clogged on these machines. The best way to repair is remove the 4 torx screws securing the control panel, On the water level switch remove clear tube from switch, with some water in tub, i suck water up and back down the tube, clearing the tube. After tube is clear spin machine for 3 mins. Test water fill again.
Dec 04, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
