Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20 I am having a problem with the picture on this tv. it looks like it is sinking in on the sides when on certain channels when its hooked to the cable box. when hooked directly to the cable source the picture is fine. the cable guys have been out and replaced the box 3 times and say it is the tv but i dont see how it can be the tv if the picture is fine when the cable is run directly to the tv. seems to me it would be the connection or the box itself thats sending the signal
    Sergeant:
    Champion:
  • 319 Answers
May have wrong diplexer. Ground potential between box and TV may cause problems. Cable techs should check to see if slitter is right
Posted on Apr 23, 2008
RCA HD52W59
I think already answered this but:
If on screen menu comes up hook up something to one of the rear av inputs and see if set works (have to move to that input with remote or input feature on front of set)
if picture etc that way tuner in set may be bad (look to see if coax fitting is loose or broken)
Mar 11, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
We recently purchased a sony bravia 55 inch tv. we have a hdm1 cord and have hd channels through Telus optik. i am not certain we have it hooked up for the best picture? can you please instruct us on what...
If you are using the HDMI input, you are using the best hook up that is available.
Is there a particular problem with the picture that does not look good?
Skyassoc
Nov 24, 2010 | Sony Televison & Video
Only getting higher channels on my tv
Replace the small signal board. You can get replacement boards from www.tvrepairworld.com
May 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture on our tv looks as if it is sinking in the middle and shows double. could this be a bulb?
The bulb would cause a dark picture or no picture at all. You have a convergence issue and the set will need to be repaired by a technician. Cost would be 150 dollars or more depending on shop rates in your area.
May 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture stands still but voice continues
Almost certainly this is not the TV. If you have the set hooked up to a digital cable box or satelite these would likely be the source of your problem.
Apr 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv shows flickering pic in an ultra violet fashion
Your tv is having convergence issues, i.e the red, green and blue are not converging properly together to give a suitable picture. you will need to replace the two convergence ics (approx cost $30 a pair), they are rectangular shaped mounted on heat sink and black in color. You will also need to check if the resistors on the output pins of each ic are not open.
and finally you will need to re-focus the red and blue using the remote.
Hope this helps!
Please rate me :D
Mar 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture Issues
When your watching non HD channels you have to stretch your screen.Your TV has that input option to do so.
May 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture goes Black
that is easy one go to options menu on video look for cc or closed caption option and turn that off
Jan 12, 2008 | Hitachi 43FDX01B TV
Whine-no picture-audio only,1 channel
bring up the menu screen the tv and auto program the channels this lock out all un wanted and only allow the rf tuner input channel from the box if your using rf cable hook up,if not un plug the unit for 1 min. and try it again.
Dec 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
