Question about Apple iPhone Smartphone
AUTOLOCK PROBLEM AFTER AUTO-LOCK(iPHONE-GENERAL SETTINGS-AUTO-LOCK) I CANT SLIDE TO UNLOCK OR ANSWER TO INCOMING CALL.I MUST PRESS BUTTON ON RIGHT TOP CONER TWICE FAST AND THEN I CAN SLIDE TO UNLOCK.SAME THING IS IF I TURN OFF AUTO LOCK AND PUT IN "LOCK"(TURN OFF SCREEN) MANUALY( BUTTON FROM TOPRIGHT CORNER). IT'S FRUSTRATING.RESTARTING IS NOT SOLUTION PERMANENTLY ONLY TEMPORARLY TO NEXT MY WIFE GIVE TO ME THAT iPHONE LIKE A PRESENT WHEN SHE CAME FROM BUSSINES TRIP FROM AMERICA.I LIVE IN COUNTRY WICH DOESN'T HAVE APPLE STORES JET SO AND SUPPORT IS IMPOSSIBLE. PHONE IS UNLOCKED WITH ZIBRI TOOL 2.5
  • BUNNDOO
    BUNNDOO Apr 13, 2008
    I TRY SEVERAL TIMES AND PROBLEM PERSIST.
    AUTO LOCK IS DISABLED,BUT iPHONE SCREEN IS ALWAYS ON IF I DON'T TURN OF MANUALY (TAP BUTTON ON TOP RIGHT CORNER) OR AUTO LOCK.
    I REINSTAL FIRMWARE 1.1.4-1.1.3,1.1.3-1.1.4. SEVERAL TIMES I CAN UNLOCK WITH ILIBERTY+,ZIPHONE IPLUS... BUT PROBLEM PERSIST.MAYBE I MUST RESTORE SECZONE BUT I DON'T KNOW HOW(WHAT COMMAND LINES AND SOFTWARE I MUST USE).WHERE CAN BE(IN WICH FILE) COMAND FOR AUTO LOCK MAYBE EDITING AND ERASE WRONG STRING CAN HELP?
  • BUNNDOO
    SOLVE BY GINKO DOESN'T HELP I NEED MORE TECHNICALY AND QUALITY SOLUTION
    New Friend:
Thanks man
It's really work
**if it's iPhone 3GS / 4 with version 4.0 and up, and the lock icon you have is with a round arrow, that mean that you locked your iPhone rotation from regular view to wide view, to unlock it you will need to press your home button twice till you see the quick navigation menu, scroll all the way to the start (you will see the play and volume option) there you will see the icon just press it once, and it will make the icon disappear, and will unlock the rotation.
Jagadish
Nepal
Posted on Jan 18, 2013
  • Apple Master
  • 19,396 Answers
Check auto lock settings and disable it
Posted on Apr 13, 2008
  • Ginko
    Ginko Apr 13, 2008
    If your Iphone displays wieird behaviour like described you may need to reinstall the firmware. Probably the firmware installed when unlocking caused the problem.
  • Ginko
    Ginko Apr 13, 2008
    I do not thing restoring seczone has got anything to do with auto lock. I will try to find out if it is a known bug or problem, I will post in the next 24 hours.
How do I reset anti theft in my 2002 ford f150
tis a process so here goes..... Central Security Module (CSM) enable/disable mode allows autolock feature to be turned on or off. To enter enable/disable mode, close all doors. Ensure ignition switch is in LOCK position. Perform the following steps within 30 seconds:
Turn ignition switch from LOCK to RUN position.
Press power door lock switch UNLOCK button 3 times.
Turn ignition switch from RUN to OFF position.
CSM module should chirp horn indicating CSM module is in enable/disable mode and ready to accept program changes.
Press power door lock switch UNLOCK button once to command CSM module to toggle autolock feature on or off. Press power door lock switch LOCK button once to enable/disable autolock feature. CSM module will chirp one time to indicate autolock has been disabled.
CSM module will chirp once, followed by a longer chirp to indicate autolock feature has been enabled. Press power door lock switch UNLOCK button once, then turn ignition switch to OFF position to exit enable/disable mode. CSM module should chirp once to verify a feature change. Best to you.
Dec 31, 2017 | Ford Cars & Trucks
My slide to unlock would not work to answer an incoming call
Maybe you didn't press on the screen firmly enough.
Sep 17, 2014 | Apple iPhone Cell Phones
Can not get password to use on iPad or iPhone to work using password
If you are asking about the passcode that locks your iPad or iPhone so others can not access it, following the steps below.
-Start with the iPad screen off.
-Press the HOME button (the small circular button close to the screen)
-Slide to unlock the screen, at the bottom.
-Press the HOME button until you see a box that says SEARCH IPAD (the keyboard will also slide up when you're on the correct screen)
-In the box that says SEARCH IPAD, type SETTINGS
-At the top of the list, created by typing SETTINGS, should be the TOP HIT of SETTINGS.
-Select SETTINGS by tapping with your finger.This will open the SETTINGS app.
-On the left hand side of the two columns, in the SETTINGS app, should be a list of options. Select the GENERAL option from the list by tapping it with your finger.
-On the right hand side of the columns should now be a list of more options starting with ABOUT.
-Continuing looking down past the ABOUT option for the option PASSCODE LOCK.
-Select the PASSCODE LOCK option by tapping it with your finger.
-A new menu, on the right hand side, should now appear starting with the TURN PASSCODE ON option.
-Select the TURN PASSCODE ON option by tapping it with your finger.
-The SET PASSCODE pad should appear in the center of your screen. Enter a four digit passcode of your choice.
-Reenter the passcode you chose again.
-You are done! The next time your iPad times out or you lock the screen, it will require the four digit passcode you set by following the above steps.
Oct 19, 2012 | Cell Phones
I want to create a privacy lock on my phone but is not working please help me
You can actually lock your iPhone so you can't accidentally use it. Well, i have this steps of solution that you need hopefully in can help you.
Find a button on the top called the sleep/wake button. The button's a tiny black button on the right side of the phone. It's not actually on the screen part of the phone, but on the silver part.
Press it and your iPhone will lock.
Unlock your iPhone by noting the locked screen. You'll see a small bar at the bottom of the iPhone with instructions to slide the bar to the right to unlock your phone actually on the screen.
Slide your finger along this bar to unlock your phone.
Remember, you can still get phone calls and text messages even when you've locked your iPhone.
Aug 29, 2011 | Samsung GTC3300 Cell Phone
Iphone screen get dark in the middle of the conversation
Changing the auto lock setting will improve that.
  1. Click the settings icon.
  2. Click the general option.
  3. Press the auto lock option.
  4. Change the settings to your heart's desire.
The phone will dim 10 seconds before whatever the time amount selected is. For example, if you chose 60 seconds for autolock, in 50 seconds, it will start to dim.
Remember, changing that option to "Never" will drain your battery life much faster if you forget to lock your phone!
May 23, 2011 | Apple iPhone 3G
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
GT-S5320: how do you de-activate the phone lock when you get incoming calls. the key pad auto lock is turned off.
This is a good question,unfortunately, we can't remove the autolock once there's an incoming or outgoing call. You just need to press the lock key on the right side for a few seconds to remove the auto lock and to make the call options come up.
Feb 11, 2010 | Samsung Star GT-S5233 Cell Phone
I cant get into my ipod cause its locked for so long.
Not sure at what level your iPod touch is locked but try this. Push the button on the top of the Touch, an Unlock slider should appear, slide it to the right. If you get passed that go to Settings / General / Autolock - set to never
Nov 24, 2009 | Apple iPod touch
Jabra BT8040 is not pairing with iPhone 3G
Make sure the headset is off. iPhone--Settings--Bluetooth---On---Press and hold the answer/end button for approx 5 secs until lite turns sold blue. It works
Nov 12, 2008 | Cell Phones
Apple iPhone Smartphone Logo
184 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
