It seems to be any button of your remote control or of TV has gone sticky. To rectify remove cell from remote and ON/Off your TV manually. If it appears again,check all buttons on TV pannel, there may be any button sticky.
If the "HI", "LO" or "CL" error codes appear on the display for more than 5 minutes, a power reset may rectify the issue. Unplug the appliance, wait 5 minutes and then plug the unit back in. If the error code persists after a power reset, contact consumer care or an authorized service agent.
Sounds like the rectifier is shorted. When it shorted out, the energy expended itself by burning through the wire. When you repaired the wire, the shorted rectifier held the excitation voltage down to zero, keeping the unit from building back up. Check the rectifier - you should find that it is shorted. There is a guy on ebay selling replacement kits - p/n 95672. You may have to flash the field after you replace the rectifier - about half the time, a rectifier or capacitor failure will kill the residual magnetism in the rotor.
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
The fall could have damaged the pcb or lines to the circuit. This is triggering the display to show the indiction. I would suggest that you ignore this as the camerra is working in good condition. If you would like to probe and think you can confidently open with precision the camera, only then make this try. It may be tricky inside to remove the flexible connections, connectors and locks. so if you can look carefully and open, check the electronics for a crack on the board.rectifying this with a solder loop would resolve the issue. if you do not want to take a chance knowing the fault to be such get a technician to open with this idea in mind. Hope you get this right.Good day
line 44, char 8862, handler already exists,URL:http://apps.facebook.com/onthefarm/index.php?ref=bookmark...... always appears lately and now i cant access farmville but i can play around with fishville... please help me to rectify this...
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash.
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
