Question about Toshiba Televison & Video
Toshiba rd-xv47,got no power.does it have a internal fuse?gegards d.fuhrmann
No. It has a nasty switch-mode power supply. These fail often - usually for no good reason. They're just poor quality.
Posted on Dec 30, 2010
Funai tv will not power up..rd light is on wwhat parts do i need to fix???
There may be an open internal fuse or the power supply has failed.
Nov 13, 2016 | Funai Televison & Video
How do I transfer stuff off a VHS on to a DVD? I have no instruction manaul for my Toshiba RD-XV47
Connect the VCR's video and audio outputs to the DVD recorder's video and audio inputs. Set up a tape in the VCR. Start recording on the DVD recorder, and immediately press "Play" on the VCR.
Aug 12, 2014 | Televison & Video
Toshiba RD-88DTKB won't switch on
Check the capacitor in the power supply board, if defective it will show a slight bulge at top, value should be around 1000uf give or take, if handy with soldering iron replace with same value and voltage rating.
Jun 05, 2012 | Toshiba Televison & Video
How do you finalize a recorded dvd on a Toshiba rd-xv47
If there is a save button, that will finalize the recording you had. You may play it on a separate file to check if it is recorded properly..
Jun 05, 2011 | Toshiba D-VR4 DVD Recorder/VCR
DEAD, NO TURN ON, CHECKED INTERNAL FUSE OK
If the internal fuse is okay, then what you got here is a bad power supply. Many power supply's do die with the internal fuse intact what happends is the High voltage tranformer or relay goes out on you causing this to happed, Best thing to do is replace the unit becuase a new power supply would cost you more then the unit new. Let me know if you have any question.
please do not forget to rate.
Aug 10, 2010 | Toshiba RD-XS32 DVD Recorder
Toshiba rd-xv47-k-tb disc problems
Please will need to change the lens
Apr 11, 2010 | Televison & Video
I need a user manual for a Toshiba RD XS 25 DVD Recorder
Go to tesc.toshiba.co.uk select "customer access" on bottom left, then select what model, etc and there you go.
Mar 12, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Hooking a vcr player to toshiba rd-xs35su
hi, connect it via a scart lead and switch to av channel.
Jan 13, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
305 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
