Question about SanDisk Sansa e250 MP3 Player
Thought it was fixed
K my Sansa E250 used to get stuck on the recovering database screen but i refresed it and installed a new frimware update and it worked fine for 10 minutes i, added new music on it and then it wouldnt even make it to the screen with the icons on it now it just stays at the scan disk screen and all it does is fade to a light blue and restart itself is there anyway to fix it or am i just screwed
  • 4 Answers
You're not screwed... Just lock your sansa and then hold REC button when starting up your sansa. Connect your sansa to the computer. then a device called 16MB-FORMAT should be in My Computer. Put this file : "http://www.MegaShare.com/392319"
onto that device. Now disconnect your sansa from your computer, and let the sansa do everything it needs to do. Then it will restart.
Make sure you unlock it. After this your sansa should work fine.
Posted on Apr 14, 2008
It keeps saying that its refresing database and is not loading
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 13, 2009 | SanDisk Sansa e250 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Sansa E200R gets stuck in refresh when I turn it on
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa screen turns black after "refreshing database"
how about updating the firmware?
OOOOHHHHH
now we are getting somewhere
( how could someone not figure that out.... ha ha ha)
Dec 20, 2007 | SanDisk Sansa e250 MP3 Player
Getting better update
Hey there
Try this link to Sansa website in which you have the frimware update
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Enjoy your Sansa
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 screen is stuck on refresh database
Press the "lock" button to where the Orange is showing. Then press the record button on the left side of the MP3 for a bit. Try this several times. I did it twice and it worked! M.P.
Aug 04, 2007 | SanDisk Sansa e250 MP3 Player
Refresh Database
This is happening alot aparently, Sandisk is telling everyone to just reset it but that aparently isnt really working. only suggestion is to set the USB mode to MTP and try it.
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
My sansa e250 won't work
I had a e260 and i thought i might share this with you. They got recalled, because ofa software malfunction. That might be what is wrong with yours, even though it's a different one it seemed to me like they were still getting the bugs out beause i upgraded to the e280 and i have to take it back too for software problems...
Apr 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
73 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
