Hinges too tight on laptop - Computers & Internet
  • dusstyb Apr 13, 2008
    I'm overwhelmed with your quick response.. and now I am searching for the hinge cover removal guide so I can try the oil.. I will tell you if it works thank you so very kindly for answering so nicely !
  • 472 Answers
This is the exact opposite problem many laptop owners face. There are a few causes, and a few soloutions.
  1. Remove the covers from the hinges and put a small drop of sewing machine oil into where the 2 hinges meet. Open and close the lid a few times to massage it in.
  2. One of the hinges could be slightly bent. The oil method above will help that aswell until it wears into it's new position.
Try that and see how you go. Do not use CRC or any spray lubricants if you can avoid it. There is a huge chance of some of the spray going inside the laptop.
Posted on Apr 13, 2008
  • Peter Thompson
    Peter Thompson Apr 13, 2008
    It's OK, Next time I will try to delay my reply so you are not so shocked =)
HINGES PRBLM
Yes. Strip down the laptop and screen. The hinges will be exposed and they can be tightened up. Use care because if too tight, they will break the plastic case.
Dec 26, 2013 | Sony VAIO VGN-UX280P Notebook
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges for your laptop maybe available from thia WEB site.
http://www.laptopparts101.com/display-screen-hinges/
Aug 27, 2012 | ASUS Computers & Internet
The screen is floppy on my Compaq Presario CQ70 and needs tightening can you inform me on how I can resolve this please ?
Check the screen mounting screws on the back of the laptop near the hinges, make sure they are tight.
If these screws ar tight and the screen is loose then the hinges need to be replaces because there are no adjustments available to tighten them.
Replacement hinges may be available from one of these WEB sites.
LAPTOP PARTS
http://www.nylaptopparts.com/
www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
http://www.sparepartswarehouse.com/
Jul 14, 2011 | HP Compaq Presario CQ70-120US Laptop
Loose Screen on Dell Inspron 1525
If the hinges are loose, it is not possible to tighten them, the hinges need to be replaced.
For details on replacing hinges, please click on these WEB sites :-
and these WEB sites for parts :-
LAPTOP PARTS www.laptoprepairco.com/
www.laptopking.com/
www.lappy.com.au/
Sep 09, 2010 | Dell Inspiron 1525 Notebook
THE LID IS LOOSE AND THERE ARE NO SCREWS TO TIGHTEN ON THE HINGES
You do not need to replace the hinges, however your need to remove the font panels of the screen and laptop to remove the hinges. You will see that the pin that connects the top part of the hinge to the bottom part of the hinges has over time moved out of alignment. With pliers and a hammer manipulate the hinge pin so that it is now flush with the hinge itself. You will see that the hinge will then become tight. Then just reinstall the hinge. I just did this and I know it works.
Oct 06, 2009 | Dell Latitude D410 Notebook
Lenovo Ideapad Y510 Hinge problem
hinges take alot of stress as they have to be quite tight to hold the screen in a certain position, alot of laptops can have over tightened hinges and cause splitting in the housing. Hinges can quite often come loose.
Make sure all screws are present around the hinge area and if you can tighten up your hinges.
If the hinges are badly damage you can buy replacments for a few $ off of ebay
Aug 22, 2009 | Lenovo IdeaPad Y510 Notebook
Solve IBM Laptop LCD Hinges Question
make shure the hinges are free from dust and debris. if too tight loosen the screws up a little.
May 23, 2009 | IBM ThinkPad T20 2647 Notebook
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Tight laptop lcd hinges
dont turn to hard they will break only solution i know is to look on ebay for new ones man
Sep 19, 2008 | Computers & Internet
Computers & Internet Logo
684 people viewed this question
David Payne
David Payne
