Question about Epson Stylus R265 InkJet Photo Printer
Black ink problem
Please can some1 help? i have a epson r265 with a cis on it. 4 5 months its bin workin perfect. now the black wont print!! arrgh!! ive cleaned it like a million times. ive had a replacement ink catridge from the supplier!! still not workin. ive cleaned the breather and tubes. ive even changed the ink!! if any 1 can help i wud b much grateful. thanx.
  • Malcolm Greenaway
    Malcolm Greenaway May 11, 2010
    Wot cartirges are you using? Epson's or and OEM lookalike?
    Problem Solver:
  • 7 Answers
It could be also the clogging of nossels in color Balck?!
For this purpose you need a special Cleaning solution, wich you
put first in the balck cartrige and start 2x cleaning(when cleaning you should observe if the balck ink is realy transported through the tube !!).Then you shut down your printer for about 24 hours.After that you clean also
for 2x times and check after that the nossels printing test. If not all nossels are free you should repeat the hole thing once again....till the nossels are free.Another problem i observed at my printer is that at some CISS ore kompatible cartriges the rubber-sealing get used with the time and do not seal enough the
conection from cartrige to printer-head and they **** only air...
For this problem i sugested a solution ..see epson stylus 1400
i hope i could help
Posted on Apr 13, 2008
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
EPSON R265 cd/dvd printer can not print in black colour I have tried to reintall the driver but still can't print in black ink. Other colours print well. Ink cartridges are new.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Jun 06, 2011 | Epson Stylus R265 InkJet Photo Printer
Ink light on
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Apr 25, 2010 | Epson Stylus R265 InkJet Photo Printer
Does not print black colour
Is it nothing black? Try this. Move cartridge to parking position. Whith only black ink tank instlaled, **** the ink from the outlet pipe of head cleaning mechanic. If there is ink, the black head is not clog. Then try to print. If it's still no black ink printing, may be the electricity of black head is lost contact. so, the micro pump can't work good.
May 27, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson 1400 wet black blocks of ink output
When this happen it means that your Fuser assembly and printer interior has toner contamination and build up. You can replace your fuser or run some more test print. Usually, the printer corrects itself.
Jul 26, 2008 | Epson Stylus 1400 InkJet Photo Printer
Epson r265
Hi - What type of discs are you using? I have an Epson 200 series printer and use these discs click here.
Also what ink are you using as some "compatible" inks do not work well on printable discs.
Best regards,
Informatica
Jul 03, 2008 | Epson Stylus R265 InkJet Photo Printer
How do I use only Blank ink on Epson R265
are you using windows or mac? on windows go to printers and faxes under control panel, right click on printer and go to printing preferences and under advance put a check mark on the box that will say grayscale or black ink only.
On mac when you click on file print go to advance tab and print setting, select grayscale or black and white.
pls dont 4get to rate the solution thanks!!
Apr 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus R265 InkJet Photo Printer Logo
281 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
