Question about Kitchen Ranges
Tricity bendix marquis sb411
Its a marquis oven grill sb411 cooker. Rings and grill working but the oven wont come on
5 Suggested Answers
SOURCE: Tricity Bendix SI450 electric cooker
On the electronic timer/control panel, the clock button has to be held in whilst the + or - buttons are used to adjust the time forward or backward. For the first twelve impulses the displayed time moves slowly, after which the display alters very rapidly. Slow mode can be returned to by releasing the clock button and + or - button and then resuming setting procedure from the time displayed. Setting the oven timer is more complicated but is essentially the same procedure using the cook button instead of the clock button.
Posted on Jun 25, 2008
SOURCE: SE454S Tricity Bendix
I have the same problem as the cooker is old.We are trying to fix the problem and when i have figured it out we will email back.
Posted on Nov 06, 2008
SOURCE: My Tricity Sovereign electic cooker,
YOU HAVE HAD A POWER CUT AND IT NEEDS TO BE RESET,I CANT REMEMBER WHICH 2 BUTTONS YOU NEED TO PRESS ON THE CONTROL PANEL BUT JUST TRY DIFF COMBOS
Posted on Dec 24, 2008
  • 3 Answers
SOURCE: main oven won't work
On ours you have to use the the timer controls; press the button with a hand symbol and the one next to it with a "-" symbol at the same time. Try a combination of the buttons on yours if this doesn't work. Weird, and took me months to figure!
Posted on Feb 15, 2009
My grill in my Tricity Bendix cooker is not working?
ISOLATE THE MAINS VOLTAGE TO THE COOKER AND GRILL, if it has a plug unplug it.
There is a regulator on the switch, you will need a tester, if this is working and continuity through the switch reducing as you increase or rotate the switch, that's working. Go to the back top a regulator is attached to the chassis of the cooker inspect for exterior damage, if not check continuity it should only conduct in one direction, and not to the chassis, if it is conducting in all , or opposite directions replace the component. You should be able to collect one from a small electrical repair shop.
Hope this is helpful.
Regards
John
Nov 01, 2014 | Ovens
I need a wiring diagram for a tricity bendix cooker top oven grill control model se54 9gr
company website has one My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Sep 29, 2014 | Tricity Bendix Cooker Selector Switch For...
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
Hi I have just moved property and I now have a tricity bendix oven that I can't get to work I have used the grill but can't use the oven
Its most probably the clock that needs resetting,by pressing the 2 rhs buttons depending on the model.Try this and hopefully the oven will work again as long as the cooker has been connected correctly.
Hope this has helped.
Jun 25, 2010 | Tricity Bendix Cooktops
Main oven won't work
Jan 12, 2009 | Tricity Bendix SE454 Electric Kitchen...
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Nov 22, 2007 | Tricity Bendix SE454 Electric Kitchen...
Kitchen Ranges Logo
226 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
