Question about Samsung SGH-E900 Cellular Phone
Samsung E900 USB Socket
I've been experiencing problems for a while now, it used to take me a long time moving the charger around whilst it was plugged in to the phone until I could get it to actually start charging, now I can't get the charger to work atall. I'm experiencing the same problem with the usb cable so I'm assuming it's the socket that's broke... The usb socket on my phone (samsung e900) must be broken because my charger and usb cable no longer work properly when plugged into it
  • Anonymous Nov 17, 2008
    same probe but on motorola k1. will not charge!!!
  • Anonymous Mar 20, 2014
    samsung sph-m580 light goes red and starts beeping. beeping sometimes gets rapid. if i plug in to charger it quits but most time i have full or almost full batt life.
The phone cant cherge thru usb buy a new chaarger
Posted on Apr 24, 2008
Samsung m320 not charging solution
Hi
I have found a manual for your phone here:
http://downloadcenter.samsung.com/content/UM/200905/20090512220605515/sprint_m320_ug_english.pdf
and around page 16 it mentions the "charger/accessories jack". Most phones will not only charge using the mains charger, but also from a USB socket on a computer. Have you tried this.
If you have then it is likely that either connections inside the phone are not working properly or even that the battery has come to the end of life. You could try removing and carefully reseating the battery to see if this helps. Also try using a multimeter (make sure it is set to the correct voltage range) to see if the charger s registering a voltage at the output plug. If it isn't a replacement charger may solve your problem.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 07, 2015 | Samsung M320 Cell Phone
My samsung laptop charger gets hot and starts to melt when pluged in and powered up and does the same if i take the battery out please helptried a new battery and new charger could it be the jack on the...
I'm unclear however
Does the new charger get too hot? If so the problem is not the charger or the socket.
Does the laptop work with the new charger plugged in but no battery? If so the socket on the laptop is probably ok
Is the actual charger melting or is it just the plug that goes in the laptop that's getting hot, if it is the plug on both chargers then the socket will need repairing or resoldering, they are a weak point, the soldered pins go high resistance and can generate a lot of heat around the plug and socket. Its usually obvious if the socket is faulty because as you move the plug it makes contact intermittently.
DONT USE THE CHARGER THAT'S MELTING and if both are getting hot have the socket repaired.
If only the one charger getting hot the short is probably in the plug on that charger but read on
On a different note the genuine chargers should be over current protected and overheat protected, they should never melt.
May 13, 2014 | Samsung Rv511 Series Laptop Intel I-core...
Hi, i've had my Samsung genio touch for over a year now and i've had no problem untill now, the phone will not charge up, i've tried putting the charger in a different socket and taking the...
a possible battery or charger problem.
check if you can charge using a diff. charger,if you can?then the charger is the problem,replace it.
but if you can charge w/a diff. battery?replace the battery. :)
Sep 09, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My samsung SGH-J700 wont turn on or charge
Time to get the ribbon cable changed. You can do this yourself with some patience after buying the cable over ebay or get it replaced at a service centre for a very cheap price.
Jul 27, 2009 | Samsung SGH-E900 Cellular Phone
Camera powers down when pressing shutter button
I see this frequently on the E900. Every time it has been a battery issue. If you're using rechargables (the E900 came with batteries and charger in the Canadian market......not sure about the rest of the planet), they may have just worn out over time. Replace with new NI-MH (nickel metal hydride) rechargeables. If you're using throw-away AA's, try Energizer Ultimate Lithiums. I've solved many, many E900 shutting off problems simply by changing the batteries to Energizer Lithiums.
May 27, 2009 | Fuji FinePix E900 Zoom Digital Camera
Using my data cable to charge my cell phone
hi thanks for using fixya!!
The data cable will not work to charge your samsung e900, you have to purchase a compatible charger for your phone.
Regards!
May 07, 2009 | Samsung SGH-E900 Cellular Phone
Samsung sgh-e900 usb connection problem
hi first things first
the e900 does not use use active sync that software is for pocket pc/pda ect
you need to download phone manager software for the e900 from the samsung site.
hope this helps
Jan 10, 2008 | Samsung SGH-E900 Cellular Phone
SGH E900 charging problem
if th emobile is under warrenty contact ur retailer.
In need of some help Pleaseeeeeeee
bluethooth file section could be full , move files from there 1st.
Oct 06, 2007 | Samsung SGH-E900 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
354 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
