Question about GE GSL25JFR Brushed Steel Side by Side Refrigerator
Grouting stainless steel tiles
Please can you recommend a grout for stainless steel tiles, The tiles i purchased have no protective covering on them. So how do i stop them from getting stratched.
  • 547 Answers
Yes use a non abrisive sand free grout
Posted on Feb 11, 2009
How to I clean the grout on my kitchen floor?
There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
High Quality Tile and Grout Cleaning in Melbourne
Oct 06, 2015 | Vacuums
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
How to Grout ceramic tile to shower base
Don't use grout! Instead use silicone caulk that matches your grout color as close as possible. Never grout where tile meets at a 90 degree angle it will crack.
Jul 13, 2014 | Building Materials
How to repair bathtub tile grout.
I would say to get a putty knife and try to carefully chissel out the grout thats there, and regrout it. Reply to my answer if you need to know how to actually grout
Oct 27, 2013 | Home
How to Clean Tile Grout?
First mop the floors to get loose dirt up, use a stiff cleaning brush ( they make small versions of toilet bowl brushes. Toothbrushes are to flimsy.) I usually use tylex to clean grout it does have bleach in it. TO keep it clean after all that hard work put down a coat of grout sealant.
Jul 06, 2012 | Home
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
GE GSL25JFR Brushed Steel Side by Side Refrigerator Logo
115 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
