Question about Canon PowerShot A75 Digital Camera
Canon Powershot A75 faulty memory card slot
The memory card was getting increasingly hard to insert and remove. The little plastic lever was reluctant to move. Now it's stuck completely and having got the memory card out, I can't get it back in. I think I may need a new CF unit. Any ideas?
    Problem Solver:
  • 5 Answers
It's possible a pin is bent on the connector in the camera. A good eye and a good flashlight and you may be able to confirm.
Posted on May 29, 2008
Even though the sd memory card is "not" in the locked position, it still says card locked when I turn my camera on. I have a Canon Powershot sd 780
Hello(Read the whole solution, i think you have the second scenario)
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Nov 27, 2010 | Canon PowerShot A530 Digital Camera
I have a Conon Powershot S1 IS camera and bought a Transcend Compact Flash 4GB memory card and when I insert in into the camera a red light flashes at the menu and set buttons?
Have your new memory card inserted into your PC to test for any virus. Format the memory car.
Please check if your cannon is adaptive to the 4GB (check the instruction manual) if the card shows the same fault now after inserting.
Use another card into the camera to confirm if the card slot is faulty.
Sep 13, 2010 | Canon PowerShot S1 IS Digital Camera
NO memory card Problem - Powershot 550
More likely one of the spring contacts in the camera that connect to the SD card has become weak causing the problem.
Mar 17, 2017 | Canon PowerShot A75 Digital Camera
Memory card error E50
Hello
Kind regards
Andrea
Apr 28, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Memory card error with new memory card
Hi there, welcome to FixYa.
Let's work on the camera first.
1) Turn the camera off and remove the battery and the card.
2) Put the battery back in without the card and turn it on.
3) Turn the camera off and insert the CF card.
4) Turn the camera back on again.
See if that takes the message away.
If it doesn't leave me a comment and we go to step 2.
If it does, thanks for coming to FixYa.
Rob
Mar 14, 2009 | Canon PowerShot A75 Digital Camera
Camera does not want to stay on
remove the memory card and try again .....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Memory card error
    Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
    Mar 03, 2008 | Canon PowerShot A530 Digital Camera
    Memory Card problems
    Remove the card and look inside the card slot of the camera to see if there are any bent pins. If you do find bent pins, you can try to bend them straight (it will be tough). If you do, DO NOT use a metal object. Use plastic or wood only.
    Dec 15, 2007 | Canon PowerShot A75 Digital Camera
    Cannot insert Memory Card
    One of the connector pins have bend inside. (Mem card reader pins) You must open camera to correct otherwise you will struggle to get to it to correct problem.
    Oct 11, 2007 | Canon PowerShot A75 Digital Camera
    Canon PowerShot A75 Digital Camera Logo
    62 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Doberman
    Are you a Canon Camera Expert? Answer questions, earn points and help others
