Dell optiplex wont boot up
Hi
I get a message that the folllowing file is missing or corrupt Windows root.\system32\ntoskernel.exe
Tried to boot from CD by changing order in bios, get press any key to boot from CD - error loading operating system
Any ideas, completely stuck
thanks
Simon
  • simon1965 Apr 13, 2008
    thanks MArk
    The dell optiplex GX150 seems to have a very limited bios, not alot around keyboardss!
  • 472 Answers
If you are using a USB keyboard, then check in the bios that USB keyboard is enabled, and also Legacy support as well.
Legacy support will allow a USB keyboard to operate under the DOS environment.
This should allow you to press the any key to start booting from CD.
Hope that helps =)
Posted on Apr 13, 2008
  • Peter Thompson
    Peter Thompson Apr 13, 2008
    Even in this day and age I still keep an old PS2 keyboard in my arsenal for just such emergencies. If you know anyone local you maybe able to get one from them to set it up.
    It is of course also possible that the disc needs a good clean. They are remarkable at collecting dust. I was even contemplating puting 50 old discs onto a stick to clean the blinds =)
\windows\system32\winload.exe missing or corrupt 0xc000000f
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
OptiPlex 760 PC Desktop: Boots with this error: Windows could not start bec...
reinstall windows xp pro. in different folder
and keep all the files
May 18, 2010 | Dell OptiPlex 760 PC Desktop
I have a Dell Optiplex GX1 desktop. I have been unable to start Windows and receive the error message: Windows root system32/ntoskrnl.450L exe failure. How do I correct this problem?
You will have to boot in to repair console from XP cd and run it so it can try to repair the Operating system. Put in cd and restart and if it does not ask to boot to cd u have to change boot order in bios to boot to CD rom first. If all this fails you have to reinstall windows. Hope this helps.
Apr 05, 2010 | Dell OptiPlex GX150 PC Desktop
Ntoskrnl.exe is missing or corrupt solution
Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution:Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 01, 2009 | Microsoft Windows XP Professional
Error: windows root>\system32\ntoskrnl.exe
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Startup problem
From: http://www.computerhope.com/issues/ch000646.htm If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps. 1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer. If you only have a restore CD, this probably won't work. You should just start the restore all over again, if this is the case.
Jun 05, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
